need some help identifying 2 wires |
captjm |
Mar 23 2024, 07:58 PM
Newbie Group: Members Posts: 6 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 |
JeffBowlsby |
Mar 23 2024, 09:08 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I’m thinking they may be to the brake switch on the MC.
captjm |
Mar 23 2024, 09:50 PM
I’m thinking they may be to the brake switch on the MC. The black protected covered wires behind the brake overflow tube caries wires down to the brake master cylinder so it still is a mystery. I think in 1970 the 914 had a fuel pump in the fuel tank area just below the mystery wires . Maybe they might have used the same harness and used them for a fuel pump? |
Mar 23 2024, 11:37 PM
The only brown/white i recall in the front trunk are for the horn(s).
No idea why that would terminate there though. (IMG:style_emoticons/default/confused24.gif) |
Dlee6205 |
Mar 24 2024, 05:37 AM
Newbie Group: Members Posts: 45 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
What's the story with the car? Is this a restoration? Has the harness been replaced? Has the harness been rewrapped?
The two wires to the MC brake switch are brown and brown/white but they're obviously not long enough. |
ejm |
Mar 24 2024, 07:44 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
The colors and location make me think they are for a brake reservoir cap with a low level sensor.
Touch them together and see if the brake light flashes. |
Shivers |
Mar 24 2024, 08:00 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
captjm |
Mar 24 2024, 08:05 AM
What's the story with the car? Is this a restoration? Has the harness been replaced? Has the harness been rewrapped? The two wires to the MC brake switch are brown and brown/white but they're obviously not long enough. I have owned the car since High School 1975. Took it apart for restoration in 1995 for restoration but life and family took priority and now its time to finish it. The harness was removed and rewrapped so probably they belong in the cab and would end around the fuse block. Mystery solved once I know for sure where they terminate. Thanks guys! |
captjm |
Mar 24 2024, 08:10 AM
What's the story with the car? Is this a restoration? Has the harness been replaced? Has the harness been rewrapped? The two wires to the MC brake switch are brown and brown/white but they're obviously not long enough. I have owned the car since High School 1975. Took it apart for restoration in 1995 for restoration but life and family took priority and now its time to finish it. The harness was removed and rewrapped so probably they belong in the cab and would end around the fuse block. Mystery solved once I know for sure where they terminate. Thanks guys! Hold the phone, I just saw Shivers post....? |
914Sixer |
Mar 24 2024, 08:15 AM
Only option that comes to mind would be a RARE gasoline heater
Shivers |
Mar 24 2024, 08:28 AM
I’ve had this car since 1982, and never messed with this area. I didn’t even know they were there until I looked.
davep |
Mar 24 2024, 08:34 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
What is the width of the spade terminals? quarter inch or half that.
I was thinking the door switch No way for a reservoir cap with a low level sensor or a gas heater! |
Shivers |
Mar 24 2024, 08:38 AM
M4 90 = electric antenna. In my pic that is the antenna coax coming through the inner fender
Shivers |
Mar 24 2024, 08:43 AM
FlacaProductions |
Mar 24 2024, 08:50 AM
Senior Member Group: Members Posts: 1,584 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I don't think i'm right but the only other thing that would have been optional in there - the wiper delay relay?
mate914 |
Mar 24 2024, 09:10 AM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
Ishley |
Mar 24 2024, 09:13 AM
Member Group: Members Posts: 96 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
I think EJM is correct. At one point Porsche was experimenting with a low fluid indicator on the brake circuit. There was a cap the had leads which would set the brake light on the dash when the fluid was low. I remember seeing a post about this. My 72 has these wires in the same spot…not terminated.
http://www.914world.com/bbs2/lofiversion/i...hp?t128210.html |
Mar 24 2024, 09:46 AM
I don't think i'm right but the only other thing that would have been optional in there - the wiper delay relay? The intermittent wiper relay wire is brown/black and if i remember correctly was not part of the harness on early cars. (IMG:style_emoticons/default/idea.gif) |
Shivers |
Mar 24 2024, 09:55 AM
https://www.autohausaz.com/pn/PO-91135535100
I saw one of these for the 924-944 for about $13.00 https://www.fcpeuro.com/products/porsche-br...ByABEgLhvvD_BwE |
Shivers |
Mar 24 2024, 12:48 PM
https://www.autohausaz.com/pn/PO-91135535100 I saw one of these for the 924-944 for about $13.00 https://www.fcpeuro.com/products/porsche-br...ByABEgLhvvD_BwE Damn, now I want to do it. (IMG:style_emoticons/default/sad.gif) I found one that mentioned a year that is close 1985. Could someone with a 85 911 go eyeball your brake fluid reservoir cap and see if they are the same? Or if someone knows if the 914 and the 911 in 85 share the same size cap. Thanks |
Lo-Fi Version | Time is now: 15th May 2024 - 07:41 AM |
