need some help identifying 2 wires |
captjm |
Mar 23 2024, 07:58 PM
Newbie Group: Members Posts: 6 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 |
rgalla9146 |
Mar 24 2024, 01:23 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
IIRC there was a black plastic relay that attached to the cowl support on later cars
('75-'76 ?) Anyone else remember it ? the support had a hole in it and the relay had a metal clip to attach through the hole. But yours is a 1970-71 ? |
Mar 24 2024, 01:29 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
IIRC there was a black plastic relay that attached to the cowl support on later cars ('75-'76 ?) Anyone else remember it ? the support had a hole in it and the relay had a metal clip to attach through the hole. But yours is a 1970-71 ? That's the intermittent wiper relay, which was not available for early cars. They don't have the needed wiring in the main harness. And as mentioned already, the wires shown don't match the colors of the intermittent relay anyways, so no, that's not it. (IMG:style_emoticons/default/popcorn[1].gif) |
JeffBowlsby |
Mar 24 2024, 01:59 PM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I could not find them on the schematic. You might get your ohmmeter out and find the other end. Not that many brown/white circuits on the car.
https://bowlsby.net/914/WiringHarnesses/doc...4_MAIN_1971.pdf |
Shivers |
Mar 24 2024, 02:51 PM
Senior Member Group: Members Posts: 2,408 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I could not find them on the schematic. You might get your ohmmeter out and find the other end. Not that many brown/white circuits on the car. https://bowlsby.net/914/WiringHarnesses/doc...4_MAIN_1971.pdf This is a piece of a 1972 914-6 schematic. Upper left hand side I put two arrows. Colors and number of wires is right. What is that? |
Mar 24 2024, 07:55 PM
There should be a number in a circle by that component. You look the number up on the key for the diagram.
A quick look at the four-cylinder wiring diagram shows the turn signal bucket connections there. Might or might not be the same on your six-cylinder diagram. --DD |
Mar 24 2024, 08:17 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have a 71
I will go take a look tomorrow and see if I have those wires. |
Lo-Fi Version | Time is now: 29th May 2024 - 12:20 AM |
