Brake light, Best way to reattach brake light wire. |
Deusexmachina77 |
Mar 29 2024, 01:51 PM
Member Group: Members Posts: 93 Joined: 30-March 22 From: Chicago Member No.: 26,426 Region Association: Upper MidWest |
As I was trying to figure out why my turn signal wasn’t working I inadvertently caused one of the two brake light wires to come detached.
Does anyone have a suggestion or retro fix to reattach the wire? I was thinking of solving it on top of the lead. Thanks Victor P.S. I fixed the turn signal. The connection inside had come undone. |
76-914 |
Mar 29 2024, 02:18 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint. (IMG:style_emoticons/default/beerchug.gif)
Deusexmachina77 |
Mar 29 2024, 04:03 PM
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint. (IMG:style_emoticons/default/beerchug.gif) Yes, but it didn’t slip out it broke off. I can’t really figure out how to pry the lead open again. It so damn small. I guess I need one of those glasses screwdrivers to pry it open. The plastic is so brittle I’m worried I’m going to break something. |
Shivers |
Mar 29 2024, 04:22 PM
Senior Member Group: Members Posts: 2,415 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint. (IMG:style_emoticons/default/beerchug.gif) Yes, but it didn’t slip out it broke off. I can’t really figure out how to pry the lead open again. It so damn small. I guess I need one of those glasses screwdrivers to pry it open. The plastic is so brittle I’m worried I’m going to break something. Is it a spade connector? Pic please |
Steve |
Mar 29 2024, 04:45 PM
914 Guru Group: Members Posts: 5,608 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint. (IMG:style_emoticons/default/beerchug.gif) Yes, but it didn’t slip out it broke off. I can’t really figure out how to pry the lead open again. It so damn small. I guess I need one of those glasses screwdrivers to pry it open. The plastic is so brittle I’m worried I’m going to break something. Is it a spade connector? Pic please (IMG:style_emoticons/default/agree.gif) If its the rear tail light housing, you should be able to remove it and solder on another terminal or worse case a wire and attach a male spade to that. |
Chris914n6 |
Mar 29 2024, 08:14 PM
Jackstands are my life. Group: Members Posts: 3,329 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
If you are talking about what we think you are, it's just a common spade connector with heat shrink over it. Crimp don't solder.
Deusexmachina77 |
Mar 29 2024, 09:56 PM
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint. (IMG:style_emoticons/default/beerchug.gif) Yes, but it didn’t slip out it broke off. I can’t really figure out how to pry the lead open again. It so damn small. I guess I need one of those glasses screwdrivers to pry it open. The plastic is so brittle I’m worried I’m going to break something. This connector is very small. I can hardly photograph it. I know this looks and sounds obvious, but these are the kind of small fixes that tend to escalate because I usually make the less than obvious solution. I’d like to try and pry open the connector but it’s so small I’m worried I’m going to just snap it off. Attached thumbnail(s) |
raynekat |
Mar 29 2024, 11:14 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I'd just try to solder that wire back right on top of the spade it broke out of.
Should be a simple quick fix with a soldering iron. Put a small piece of "shrink sleeve" on the wire before you solder it back. Then use a heat gun on the sleeve and you'll have a fairly professional fix that should last. |
Deusexmachina77 |
Mar 30 2024, 09:40 AM
I'd just try to solder that wire back right on top of the spade it broke out of. Should be a simple quick fix with a soldering iron. Put a small piece of "shrink sleeve" on the wire before you solder it back. Then use a heat gun on the sleeve and you'll have a fairly professional fix that should last. (IMG:style_emoticons/default/agree.gif) |
76-914 |
Mar 30 2024, 11:50 AM
I'd just try to solder that wire back right on top of the spade it broke out of. Should be a simple quick fix with a soldering iron. Put a small piece of "shrink sleeve" on the wire before you solder it back. Then use a heat gun on the sleeve and you'll have a fairly professional fix that should last. (IMG:style_emoticons/default/agree.gif) Isn't that what I just said in post #2? (IMG:style_emoticons/default/confused24.gif) |
raynekat |
Mar 30 2024, 10:43 PM
Yes, it definitely is. You had a great idea! |
Deusexmachina77 |
Apr 7 2024, 03:39 PM
Yes, it definitely is. You had a great idea! I ended up laying the wire on top of the terminal and using one of those heat shrink tubes with the solder inside. The solder wrapped around the wire and terminal. It works. We’ll see how long it lasts. |
Lo-Fi Version | Time is now: 4th June 2024 - 09:09 PM |
