QUOTE(Deusexmachina77 @ Mar 29 2024, 04:03 PM)
QUOTE(76-914 @ Mar 29 2024, 02:18 PM)
Are you saying that the crimp terminal separated from the wire? If so, you can strip the plastic sheathing away and solder the wire to the small crimp connector. Just be sure to use some heat shrink to cover the bare spot on the terminal/solder joint.
Yes, but it didn’t slip out it broke off. I can’t really figure out how to pry the lead open again. It so damn small. I guess I need one of those glasses screwdrivers to pry it open. The plastic is so brittle I’m worried I’m going to break something.
This connector is very small. I can hardly photograph it. I know this looks and sounds obvious, but these are the kind of small fixes that tend to escalate because I usually make the less than obvious solution. I’d like to try and pry open the connector but it’s so small I’m worried I’m going to just snap it off.
