How much oil in dry sump tank stock 914-6, Removing oil with suction pump? |
morehills |
Apr 7 2024, 08:33 AM
Newbie Group: Members Posts: 29 Joined: 2-March 23 From: Great Barrington, MA Member No.: 27,202 Region Association: North East States |
I'm changing oil in stock '71 stock 914-6 set up for the first time after a day at the track yesterday. Rather than disconnect lines under the engine, I'm drawing out oil from the dry sump tank with a suction pump. Does anyone know the capacity of these tanks at proper fill? Just need an estimate for what to extract. Thanks, John
mb911 |
Apr 7 2024, 08:36 AM
914 Guru Group: Members Posts: 6,875 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I'm changing oil in stock '71 stock 914-6 set up for the first time after a day at the track yesterday. Rather than disconnect lines under the engine, I'm drawing out oil from the dry sump tank with a suction pump. Does anyone know the capacity of these tanks at proper fill? Just need an estimate for what to extract. Thanks, John Factory setup is 9 QTs |
morehills |
Apr 7 2024, 10:20 AM
Thanks. I was asking about capacity of the oil tank mounted in the fender.
Superhawk996 |
Apr 7 2024, 10:36 AM
914 Guru Group: Members Posts: 5,886 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Didn’t like the answer ? (IMG:style_emoticons/default/confused24.gif)
technicalninja |
Apr 7 2024, 10:40 AM
Senior Member Group: Members Posts: 1,309 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
You're going to have to figure that out by yourself.
Get oil level perfect and then go to town with your sucker. My first question is why? Are you only going to change the oil in the tank? |
mlindner |
Apr 7 2024, 10:59 AM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Extract all you can get, maybe 8 8 1/2 quarts. you will have oil in the filter and some in the engine case if your not going to drain that. Like mb911 said 9 quarts. Then top up as needed, warn running engine on dip stick.
brant |
Apr 7 2024, 11:41 AM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
You need to drain the engine case also
Any motor that’s broke in will allow oil past the pump and into the case as it sits overnight |
morehills |
Apr 7 2024, 12:11 PM
Thanks. Perhaps my question wasn't clear or I double posted. I've drained the case. Now I'm draining the tank from the top with a suction oil remover rather than disconnecting the oil lines under the car. Simply wanted to know the capacity of the stock oil tank so I'll have an idea when it's complete. If anyone knows it please let me know.
rick 918-S |
Apr 7 2024, 12:25 PM
Hey nice rack! -Celette Group: Members Posts: 20,478 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
How are you getting the suction tube past the screen?
rgalla9146 |
Apr 7 2024, 07:06 PM
Advanced Member Group: Members Posts: 4,564 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
How are you getting the suction tube past the screen? (IMG:style_emoticons/default/agree.gif) Rick... Beat me to it. |
Superhawk996 |
Apr 7 2024, 07:21 PM
Thanks. Perhaps my question wasn't clear or I double posted. I've drained the case. Now I'm draining the tank from the top with a suction oil remover rather than disconnecting the oil lines under the car. Simply wanted to know the capacity of the stock oil tank so I'll have an idea when it's complete. If anyone knows it please let me know. Dude - get real. You have been given the answer multiple times by multiple people - all running a six. I’m not trying to be rude but it’s rude to keep asking, especially when the answer is readily available to be verified by google if you don’t want to believe the guys running a six, and the guy that makes tanks. |
mskala |
Apr 8 2024, 05:55 AM
I'm pretty sure the OP is interested in how much oil stays in the tank vs. stays in the 'pan'. This is a perfectly normal question. Unfortunately, there's no solid answer, as it has been said, some will drain out of the tank depending on oil itself and how long car has been sitting. Also, most of these cars leak and burn oil, so me, personally, I never know how much is in the car anyway. Disconnecting the lines is not a big deal.
gereed75 |
Apr 8 2024, 07:56 AM
Senior Member Group: Members Posts: 1,253 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
So just to reiterate really hard to know. Started out 9 qts. Some stays in filter, lines and the case and some burned . So how much is in tank is a guess
And regardless, don’t think you can get a siphon tube into the bottom anyway. There is a screen and separator baffles Many people put some sort of drain in the connector between the tank line and the cooler line. Without a drain, cracking the fittings is the way. |
mb911 |
Apr 8 2024, 01:31 PM
Gosh this is not that hard. 9qts empty system. Drain tank and sump and it should equal 9 QTs. Refresh with 9 QTs in the tank and run the engine to circulate |
Lo-Fi Version | Time is now: 4th June 2024 - 09:15 PM |
