Where to find light bucket spring?, Follow up question… |
Montreal914 |
Apr 9 2024, 08:00 PM
Senior Member Group: Members Posts: 1,571 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
I recently sent a bunch of part for plating and way too many of them got lost in the process. Not going to talk about this...
Among those, the springs that are in the light bucket assemblies. Does anyone know the actual part number for it and where I can get two new ones? Thanks! (IMG:style_emoticons/default/smile.gif) This! |
914Sixer |
Apr 10 2024, 08:57 AM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Probably at ACE Hardware IF you have one to measure
Montreal914 |
Apr 10 2024, 09:13 AM
Yeah… seeing there aren’t any answers, I was getting to this follow up question…
Can someone measure the OD and the wire diameter ideally using a caliper? (IMG:style_emoticons/default/pray.gif) Fronm the picture (Google) the spring has 12 coils. I wish I had measured them before sending the two sets I had to plating… (IMG:style_emoticons/default/dry.gif) Thank you! |
bdstone914 |
Apr 10 2024, 07:26 PM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@Montreal914
' I sourced a similar spring at McFaddendale hardware but the tension was less. The diameter on the wire matters too. Best to get one from another bucket. You could try Mcmastercarr.com |
Montreal914 |
Apr 10 2024, 08:01 PM
I need the wire diameter and the spring diameter. These should be measured with calipers ideally.
I will not just buy something as I have nothing to reference it to. Knowing it has 12 coil, with the two requested dimensions we are good to determine the spring. (IMG:style_emoticons/default/smile.gif) |
dr914@autoatlanta.com |
Apr 11 2024, 09:52 AM
914 Guru Group: Members Posts: 7,885 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have literally hundreds on the shelf from donor 914 headlamp assemblies
I recently sent a bunch of part for plating and way too many of them got lost in the process. Not going to talk about this... Among those, the springs that are in the light bucket assemblies. Does anyone know the actual part number for it and where I can get two new ones? Thanks! (IMG:style_emoticons/default/smile.gif) This! |
Lo-Fi Version | Time is now: 31st May 2024 - 06:37 PM |
