Fresh Air Box Rebuild - Replacing Blower Motor |
DC_neun_vierzehn |
Apr 13 2024, 08:21 AM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
My wiper assembly is not parking properly (as discussed in this post) so I need to perform the dreaded task of pulling the fresh air box to get to the wiper assembly. I've watched Ian's video which is super helpful.
I'd like to rebuild the air box while I have it out. I bought the 914 Rubber kit to replace all of the seals and grill. I'd like to replace the fan motor too while I'm in there. My question: is this the right part (or best part) for a 914 fresh air box? https://sierramadrecollection.com/products/...ly-69-89-p18608 |
914Sixer |
Apr 13 2024, 08:30 AM
Should work fine. $10 cheaper at Rockauto.
PanelBilly |
Apr 13 2024, 10:22 AM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I replaced mine and was so happy to have a defrost again bit of a task, but well worth the effort
jim_hoyland |
Apr 13 2024, 10:42 AM
Get that VIN ? Group: Members Posts: 9,297 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Do the new replacement fan motors put out more air ?
PanelBilly |
Apr 13 2024, 12:32 PM
Seems like it bur it might just be that they work properly
76-914 |
Apr 14 2024, 07:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
FYI, You won't be able to use Ian's clamp unless you pull the hood. I just did this and wished I had done a video on it. The 914rubber gasket between the halves is pretty thick so I recommend you assemble, wait a few days then retighten to compress that seal even more. You will need every 1/10mm you can get. More importantly; use a thin bead of black silicone to adhere the new grille/gasket combo. It's much more solid & you won't need to futz with the runner bands to hold in place. (IMG:style_emoticons/default/beerchug.gif)
DC_neun_vierzehn |
Apr 14 2024, 03:32 PM
Thanks everyone. Appreciate the pointers. I need all the help I can get on this one.
jim_hoyland |
Apr 15 2024, 06:44 AM
Thanks everyone. Appreciate the pointers. I need all the help I can get on this one. Show us some pics; this is a very tricky area to work in (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) |
DC_neun_vierzehn |
Apr 16 2024, 09:35 AM
Thanks everyone. Appreciate the pointers. I need all the help I can get on this one. Show us some pics; this is a very tricky area to work in (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) Will do my best to document. I'm trying to knock out 3 jobs at the same time: fuel tank replacement, fresh air box rebuild, wiper assembly adjustments and/or replacement. I'm dreading it, to be perfectly honest. |
DRPHIL914 |
Apr 18 2024, 11:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Do the new replacement fan motors put out more air ? Thanks everyone. Appreciate the pointers. I need all the help I can get on this one. Show us some pics; this is a very tricky area to work in (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) Will do my best to document. I'm trying to knock out 3 jobs at the same time: fuel tank replacement, fresh air box rebuild, wiper assembly adjustments and/or replacement. I'm dreading it, to be perfectly honest. @jim_hoyland @DC_neun-Vierzehn this will work great along with the rebuild kit seals etc from 914rubber, Ian's video much help, a couple years ago i did a thread on this too. Yes they push a lot more air than i thought they would. ! |
jim_hoyland |
Apr 18 2024, 11:57 AM
Do the new replacement fan motors put out more air ? Thanks everyone. Appreciate the pointers. I need all the help I can get on this one. Show us some pics; this is a very tricky area to work in (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smile.gif) Will do my best to document. I'm trying to knock out 3 jobs at the same time: fuel tank replacement, fresh air box rebuild, wiper assembly adjustments and/or replacement. I'm dreading it, to be perfectly honest. @jim_hoyland @DC_neun-Vierzehn this will work great along with the rebuild kit seals etc from 914rubber, Ian's video much help, a couple years ago i did a thread on this too. Yes they push a lot more air than i thought they would. ! Thanks; that’s my biggest complaint- air flow is minimal at the highest setting |
914sgofast2 |
Apr 18 2024, 12:34 PM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
When I did my airbox, I found that the new gasket that fits between the upper and lower halves of the plastic airbox was too thick, once you put the new upper gasket onto the top of the airbag and tried to re-install the assembly under the body cowl sheetmetal. So, I took out the plastic airbox' middle gasket used a bead of black silicon to seal the motor lower half against the airbox' upper half. With that modification, the refreshed air box fit into place just fine without the need for Ian Karr's tool setup or the need to remove the hood. The metal body cowl area is pretty flexible if you remove the bolts on each of the metal arms which support the upper cowl sheetmetal.
Lo-Fi Version | Time is now: 16th May 2024 - 08:59 PM |
