FS 1.8 engine, needs minor work to be a runner again, Put on carbs and install a spark plug helicoil |
B2524 |
Apr 18 2024, 02:35 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Was running in a car i bought but needed the plug helicoil installed. Some FI is there but I would say put carbs on it.
No exhaust, needs some leaky gaskets and seals replaced. Think of it as a temp engine as you rebuild your matching numbers engine or as a core to build into your fantasy hot rod engine. $500 pick up only outside Paso Robles CA. Imagine just about every used 914 engine you’ve seen, good no pics are necessary then. |
Lo-Fi Version | Time is now: 16th May 2024 - 11:05 PM |
