Console Wiring Connections |
Gatornapper |
Apr 22 2024, 06:40 PM
Senior Member Group: Members Posts: 1,205 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
I'm getting ready to put gauges in Ruby.
Where are the Center Console Wiring Harness connections? I have the diagram. (IMG:http://www.914world.com/bbs2/uploads_offsite/hosting.photobucket.com-21449-1713832818.1.jpg) Are these them? https://www.pelicanparts.com/techarticles/9...e_pic21_big.JPG Not enough wires and they don't match up. TIA, GN |
JeffBowlsby |
Apr 22 2024, 07:04 PM
914 Wiring Harnesses Group: Members Posts: 8,488 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Attached thumbnail(s) Attached image(s) |
Gatornapper |
Apr 22 2024, 07:13 PM
Jeff -
PERFECT! The sketches of the connectors explain it all! The diagram at top implies 3 black connectors - 3 brown, etc. - not one. Repeat. So simple - got it now! Piece of cake! Thanks so much! GN |
Gatornapper |
Apr 22 2024, 07:24 PM
Top drawing misleads because it even says that each yellow rectangle is each a 6mm female spade terminal.........I have over 50 years of believing electrical drawings to mean what they say!
But now I see only the 5 at the bottom refer to what is on the floor........my bad..... I can easily make my own harness...... GN |
TROJANMAN |
Apr 22 2024, 07:35 PM
Looks nice in pictures......... Group: Members Posts: 5,259 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Kind of on topic......What does this (black) harness connect to? (IMG:style_emoticons/default/idea.gif)
asking for a friend...... (IMG:style_emoticons/default/ph34r.gif) Attached image(s) |
JeffBowlsby |
Apr 22 2024, 10:11 PM
What harness? The black plastic connecor housing under the passenger seat?
TROJANMAN |
Apr 22 2024, 10:43 PM
Luke M |
Apr 23 2024, 05:34 AM
Senior Member Group: Members Posts: 1,370 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Kind of on topic......What does this (black) harness connect to? (IMG:style_emoticons/default/idea.gif) asking for a friend...... (IMG:style_emoticons/default/ph34r.gif) That's the seat belt interlock relay housing. It would have 2 relays attached to that housing. Looks like it's been jumped already. See the larger yellow/red wire that's been spliced together. That's the fix. I would take a look at splice job. Most of the time they are just butt connected together. I would clean that up and solder those wires together. Rest just tape up and leave under the seat. I jumped out my brother's 74 but left everything in the factory location. |
NARP74 |
Apr 23 2024, 08:26 AM
Senior Member Group: Members Posts: 1,057 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Lo-Fi Version | Time is now: 3rd May 2024 - 06:02 PM |
