> Recommended muffler for /4 header??
Mueller
post Feb 7 2003, 04:15 PM
914 Freak!
Just ordered a Eurorace header (now European Motorworks).....so now I need to search for a muffler.....I've heard the single chamber Flowmaster that is running on "Julius" and I'd like something a little quieter.......huh??
For you smart-asses out there...yes, this time I am getting a real header, not a Bursch without the muffler (IMG:style_emoticons/default/ohmy.gif)
campbellcj
post Feb 7 2003, 04:25 PM
I can't Re Member
I have a full-size Flowmaster 40-series Delta Flow on my eurorace header. It's a 2" inlet/outlet that is attached via a short stub tube with the 3-hole flange welded on.
It exits straight out back from the collector (no bends) and is hanging from a mount attached to the trunk bulkhead/firewall.
It is still very loud under heavy throttle, but probably not quite as much as the tiny drag-race Flowmaster Brad used. At idle and cruise it is pretty mellow and tolerable.
Jegs (www.jegs.com) has the full range of Flowmasters in just about every size and noise-level desired. They are around $70/ea.
jonwatts
post Feb 7 2003, 04:40 PM
no rules, just wrong
Dude, you're a glutton for punishment bringing that up again.
Mueller
post Feb 7 2003, 04:43 PM
914 Freak!
I'm ignoring you Jon, (fingers in ears...lalalalalala)
Speaking of exhausts and such...Pete Weber, wrote this that is a good read:
Pete Weber article
Demick
post Feb 7 2003, 04:49 PM
Ernie made me do it!
Mike
I've got a Flowmaster 40 series Delta Flow muffler as well. 2" center inlet, 2" offset outlet. Welded onto a Bursch style collector with SS heat exchangers. Works well, fairly loud. I would have preferred to use a 50 series Delta Flow instead for a little more mellow sound, but it was 4 inches longer than the 40 series and wouldn't have fit.
Demick
'74 2.0
ChrisFoley
post Feb 7 2003, 09:52 PM
I am Tangerine Racing
Chris Farley Racing, LOL!
Maybe I should change the name...
- Lo-Fi Version Time is now: 18th July 2025 - 07:54 PM
