Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Some footage of a four-cylinder 914 out on track. The first corner is a bit ... scruffy, but he gathers it back up and gets going reasonably well.
https://www.youtube.com/watch?v=2Psn3k9_oek --DD |
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,009 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Nice run, but I can't believe they let you drive on the track wearing shorts! Long sleeve shirt and pants should be the norm.
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,217 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Never gets old seeing a 914 pass by a tail dragger.
Superhawk996 |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,505 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
Artfrombama |
Member ![]() ![]() Group: Members Posts: 330 Joined: 21-January 24 From: Huntsville, Alabama Member No.: 27,870 Region Association: South East States ![]() ![]() |
Fast in, slow out
Slow in, fast out |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,307 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
Nice driving!
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm thinking that's not in the USA. Speedo is in Kilometers. Germany? Fun video. (IMG:style_emoticons/default/beerchug.gif)
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,010 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I thought his suspension tune could use a little more balance and front end bite. I’m sure a historic racing in Europe limits his tire choice. But the balance can still be achieved through spring choice
Plus a bigger front anti roll bar |
brant |
Duplicate
Superhawk996 |
I thought his suspension tune could use a little more balance and front end bite. I’m sure a historic racing in Europe limits his tire choice. But the balance can still be achieved through spring choice Plus a bigger front anti roll bar Say what??? Typically increasing front roll stiffness either by spring or by anti roll bar will increase understeer. [note: I know you didn’t say increase front spring rate] There may be edge cases where a bigger front anti roll bar would help decrease understeer (if car is starting with huge body roll) but not knowing anything about that particular car and its setup, I wouldn’t be proposing more front bar to help front end “bite”. Maybe we are just not using the world “bite” the same way? . When I hear bite, I hear “grip”. In the case of an oversteering vehicle, the front end has more “bite”, more grip (traction) than the rear. As a result the rear lets loose and rotates faster than the front end. If the proposal is to add more understeer via more front roll stiffness to reduce the car’s tendency to oversteer - I’m with you 100%. All things being equal, the same effect could be achieved by reducing rear bar and/or rear spring rate. I’m not trying to be pedantic. However I feel it’s important discussion because so many guys are thinking they need huge front anti roll bars and huge torsion bars because of what they read on these forums. Too often people just want to follow a “formula” rather than understanding vehicle dynamics. Note: one of the hardest parts of racing is getting the whole crew using the same language and having a common understanding of the language. This post isn’t meant to disparage Brant or imply he’s wrong or doesn’t understand race car setup. |
brant |
Actually i shouldn’t have been that specific
It would depend what the current spring rates, and both anti sways are currently. Plus a trip to the scales and potentially adjusting ride height or the rake I do mean grip Agreed he may be on the limits but still see a little push starting the corrections I agree with softening the front |
Superhawk996 |
Actually i shouldn’t have been that specific It would depend what the current spring rates, and both anti sways are currently. Plus a trip to the scales and potentially adjusting ride height or the rake I do mean grip Agreed he may be on the limits but still see a little push starting the corrections I agree with softening the front Yeah - it’s an interesting video. Wish I had data acquisition to go with it to understand the car more. It oversteers, it understeers, and is neutral at other times. Driving behavior has huge influence in how it shifts between these behaviors. Sometimes I see him go to the throttle and then the understeer starts as the front end unweights. Can get the opposite (oversteer) effect by abrupt lift throttle and braking while turning in. Then there also appears to me to be some aerodynamic changes where it oversteers more at low speed but less at high speed. Likely front end lift at higher speed providing some front end lift and increased understeer behavior that prevents the oversteer at higher speed. Again, all reasons that simply copying what works on the track may not be the best thing for the average guy driving on the street. Thanks for understanding the intent of the previous post. (IMG:style_emoticons/default/beerchug.gif) |
peteinjp |
Member ![]() ![]() Group: Members Posts: 211 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None ![]() ![]() |
I'm curious about what unsettles the car at 10:23? Is it just the tire breaking lose?
Pete |
flat4guy |
Member ![]() ![]() Group: Members Posts: 470 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California ![]() |
Time for stickier tires and some suspension tuning. Fun to watch though.
emerygt350 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,002 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States ![]() |
moto914 |
Member ![]() ![]() Group: Members Posts: 59 Joined: 27-February 17 From: Greenville SC Member No.: 20,878 Region Association: South East States ![]() ![]() |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,688 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Thanks for sharing Dave...But you need to heel and toe on the down shifts. Engine speeds needs to match wheel speed so rear wheels don't break loose.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
So many ideas and comments...its great to see him out learning how to drive his car on a track...I do think the shorts is a bit much.
Rich |
Lo-Fi Version | Time is now: 7th July 2025 - 11:58 PM |
