| cause |
Aug 17 2024, 05:20 PM
Newbie ![]() Group: Members Posts: 45 Joined: 6-May 21 From: new york Member No.: 25,514 Region Association: None |
Finally assembled all of the missing bits to put heat in my car—however I am now running into electrical issues it seems.
what I think are two separate issues I'm experiencing:
If any folks are decently local to NY/NJ area I'd really appreciate extra eyes on figuring this out—im so close yet so far. :/ |
| emerygt350 |
Aug 18 2024, 06:27 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,476 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Which wire is getting hot? The one in the cab?
What sparks? The lever or the relay? I'm way up by Ithaca so I wouldn't be much use. |
| Superhawk996 |
Aug 18 2024, 07:52 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,737 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Your heater wiring is jacked up and shorting. As you stated, the motor is supposed to be controlled via switched ground.
Schematic and DMM will be necessary to troubleshoot and repair. I don’t guess at electrical issues. First step is measure with DMM and confirm that you do indeed have 12v on the heater control wire instead of Ground. |
| cause |
Aug 18 2024, 10:33 AM
Well, idk what I did—but I took everything apart and put it back together again (for the 15th time) and now everything works...
| ctc911ctc |
Aug 18 2024, 12:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,316 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
I wrote a very long and focused recovery note on resurrection of these motors.
http://www.914world.com/bbs2/index.php?sho...=367558&hl= They are very interesting self-centering electric motors..........What is sometimes lost is the insulation that is between the mounting bracket and the motor. It isolates the vibration and ground from the connection between the motor and the chassis of the car. My guess is that you are missing this insulation and the motor is always grounded. Well, idk what I did—but I took everything apart and put it back together again (for the 15th time) and now everything works... |
| 914_teener |
Aug 18 2024, 01:22 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I wrote a very long and focused recovery note on resurrection of these motors. http://www.914world.com/bbs2/index.php?sho...=367558&hl= They are very interesting self-centering electric motors..........What is sometimes lost is the insulation that is between the mounting bracket and the motor. It isolates the vibration and ground from the connection between the motor and the chassis of the car. My guess is that you are missing this insulation and the motor is always grounded. Well, idk what I did—but I took everything apart and put it back together again (for the 15th time) and now everything works... Great thread and in my car two things had happened. The car had sat and the PO discarded the fan which had frozen. I purchased a working one too replace it but upon inspection found that plugging in the lead would short and blow the fuse. Turns out, the brown wire to the handle had melted the insulation to the feed circuit in the tunnel . I surmised that the previous owner let the car sit which froze the motor which heated up the grounding wire screwing up the harness leads. Replacing the wire and a second hand fan that functioned remedied the problem. I can only say it took a few days of head scratching to figure out what was wrong. |
Lo-Fi Version | Time is now: 16th March 2026 - 12:13 AM |
