what I think are two separate issues I'm experiencing:
- When testing to see if the fan works at all, I had it disconnected from the main wiring harness and used a jumper wire to connect it directly to the battery—which it does come on, but doesn't need to be grounded with the second wire, is that normal?
- (Without the fan plugged into the harness still) Only when I have the relay in the circuit board and when heater lever is engaged it sparks and the wire gets super hot/melty. I understand that its just a ground wire, so where could the voltage be coming from and shorting out?
If any folks are decently local to NY/NJ area I'd really appreciate extra eyes on figuring this out—im so close yet so far. :/
