| Literati914 |
Aug 27 2024, 01:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,341 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Who carries the washer's that fit under the top seals/grommets of the Master Cylinder? I've contacted a couple places with no luck. Also, have a message out to 914rubber - if that was gonna be a suggestion. But you can find the seals/grommets all day long but not so with the required washers, apparently.
Alternatively, I'd order off just the size IF there's nothing special about them. Does anyone know this and/or the dimensions? #18 in the diagram 901 355 936 00 Attached image(s)
| bdstone914 |
Aug 27 2024, 02:07 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,322 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Who carries the washer's that fit under the top seals/grommets of the Master Cylinder? I've contacted a couple places with no luck. Also, have a message out to 914rubber - if that was gonna be a suggestion. But you can find the seals/grommets all day long but not so with the required washers, apparently. Alternatively, I'd order off just the size IF there's nothing special about them. Does anyone know this and/or the dimensions? #18 in the diagram 901 355 936 00 Did you call Porsche with that number? |
| mepstein |
Aug 27 2024, 02:13 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,773 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I have a Porsche dealer where I can swing by and pick up parts. They get those washers for me without a shipping charge.
Attached thumbnail(s) |
| dr914@autoatlanta.com |
Aug 27 2024, 02:23 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,240 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we sell many many of these stainless washers as they are critical to the seating of the feed lines from the reservoir so that the lines will not leak
Who carries the washer's that fit under the top seals/grommets of the Master Cylinder? I've contacted a couple places with no luck. Also, have a message out to 914rubber - if that was gonna be a suggestion. But you can find the seals/grommets all day long but not so with the required washers, apparently. Alternatively, I'd order off just the size IF there's nothing special about them. Does anyone know this and/or the dimensions? #18 in the diagram 901 355 936 00 |
| Literati914 |
Aug 27 2024, 02:39 PM
we sell many many of these stainless washers as they are critical to the seating of the feed lines from the reservoir so that the lines will not leak Who carries the washer's that fit under the top seals/grommets of the Master Cylinder? I've contacted a couple places with no luck. Also, have a message out to 914rubber - if that was gonna be a suggestion. But you can find the seals/grommets all day long but not so with the required washers, apparently. Alternatively, I'd order off just the size IF there's nothing special about them. Does anyone know this and/or the dimensions? #18 in the diagram 901 355 936 00 @mepstein I appreciate the info - I'm gonna place an order with George though 'cause I need a few other bits and pieces. George @dr914@autoatlanta.com - Thanks for the heads-up, 'cause I have problems finding stuff on your site sometimes tbh. |
Lo-Fi Version | Time is now: 15th June 2026 - 12:11 PM |
