Who carries the washer's that fit under the top seals/grommets of the Master Cylinder? I've contacted a couple places with no luck. Also, have a message out to 914rubber - if that was gonna be a suggestion. But you can find the seals/grommets all day long but not so with the required washers, apparently.
Alternatively, I'd order off just the size IF there's nothing special about them. Does anyone know this and/or the dimensions?
#18 in the diagram 901 355 936 00
