| drdriddle |
Sep 3 2024, 03:16 PM
Newbie ![]() Group: Members Posts: 30 Joined: 16-March 23 From: montana Member No.: 27,230 Region Association: None |
I am running an alpine radio that has a dimmer function wire. It hooks somewhere, I assume, into the headlight switch. This should allow the radio illumination to match the dash light illumination when the headlight switch is pulled on. I know the headlight switch has a rheostat that controls the light output for the dash but the switch itself has multiple poles off of it and i have no idea if one of them is responsible for what im looking for.
Anyone have any ideas? the wire diagrams i have in the hayes manual are very small and don't really help please and thank you |
drdriddle Need help on wiring Sep 3 2024, 03:16 PM
87m491 Grab your DVM and ground the negative test lead, t... Sep 3 2024, 03:25 PM
davep Well this is pretty easy, at the rear of the switc... Sep 3 2024, 04:45 PM
drdriddle
Well this is pretty easy, at the rear of the swit... Sep 3 2024, 04:54 PM
Spoke @drdriddle
The dimming wire from the headlight s... Sep 3 2024, 05:27 PM
JeffBowlsby Yes, connect to any black/blue stripe wire in the ... Sep 3 2024, 06:06 PM
Spoke You can use one of these piggyback spade connector... Sep 3 2024, 06:07 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 06:49 PM |
