| Aaron Cox |
Aug 25 2005, 11:14 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
some cool materials available, along with some in between bore sizes....
things to worry about... stud pattern? lip where they meet the head? Bottom where they meet the case? just curious if it had been done, IIRC ive seen it... |
| Mueller |
Aug 25 2005, 11:29 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
964 or 993 cylinders and heads have been adapted before, I thought at one time Jake was even going down this path.....
A shop in England has done it with good results...if you have ask, you cannot afford it applies here (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
| jonwatts |
Aug 25 2005, 11:30 PM
no rules, just wrong ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
I don't know, but if it were easy I don't think they'd have gone to the trouble of making nikkies.
| bernbomb914 |
Aug 26 2005, 01:48 AM
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
There was a post from a fellow from europe on shoptalkfourm who was doing this with pics. It has been some time thou.
Bernie |
| Jake Raby |
Aug 26 2005, 02:41 AM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
doing it as we speak... The only advantage to using them is if you need the extra head sealing capability of the RSR cylinder/Head gasket from the Big Turbo engine... OR if you want to run 911 heads. I'm doing it for 4 other reasons on this engine that I'll share later on another channel-
I am using a set of Charles' 911 cylinders in the 102mm bore size (3.8 RSR) to create a 2680cc Intercooled Turbo for a customer in Germany. We just started the case mods now and the project will take clear through May 2006 to finish because of so much one off work.. (FYI Charles has an RSR customer pumping 40 PSI boost through a set of these same 911 cylinders) The key to make it all work you need to attach two pieces of blanchard ground Aluminum plate to the case with several different attachment methods and then rebore the new stud pattern into the plate as well as the cylinder registers. I used .700 Aluminum plate because the RSR cylinder is .650 shorter than a TIV cylinder from seating surface to seating surface and it will allow me the capability of creating equal length head studs to overcome another engineering faults that our buddies at VW gave us.....(wit till you see how we are doing this- you'll freak) So....... Don't even think about doing this unless you have a full machine shop at your disposal- The normal person would never have to even worry about it- Just buy TIV Nickies and be done... But making 400 Reliable ponies and holding 25 PSI boost is another whole world.... We need all the help and tricks we can throw at it. Hell I have 30 hours labor in it so far and I don't even have the welding and initial machine fitting done yet!!!!! |
| Dave_Darling |
Aug 27 2005, 09:00 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,324 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
It's also been done by modifying the cylinders, rather than all the stuff Jake is talking about. I'm not sure how well it worked, though. Didn't Wes over at H&H have something to do with one setup like that?
A whooooooole lotta machining was required though. --DD |
| Jake Raby |
Aug 27 2005, 09:24 AM
Yes, you could relocate the stud pattern by boring the holes larger and offset in the cylinder- But thats the half assed way to do it and it weakens the cylinder. You'd still need a .650 shim under the cylinder to even get back to zero for a stock engine- a stroker may need .900!
| scotty914 |
Aug 27 2005, 11:01 AM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
what about the guy who makes 4 cylinder motors using 911 pistons and cylinders, his own heads, his own case, and basicly a cut down -6 crank. what he makes is basicly a 4 cylinder -6 motor
| Gary |
Aug 27 2005, 11:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 12-January 03 From: Mount Airy, MD Member No.: 134 Region Association: MidAtlantic Region
| Jake Raby |
Aug 27 2005, 11:23 AM
Yeah.. about the same cost as one of my "Super Heros" that will make MORE TORQUE!
The 911 engine does not supercede the girth of the TIV bottom end and case- the TIV had to hold the weight and load of a 5,000 pound bus, not a 3,500 pound sports car... |
Lo-Fi Version | Time is now: 13th February 2026 - 08:13 AM |
