| boxstr |
Aug 26 2005, 05:01 PM
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
I have the steering wheel off and the t. signal levers out and I need to know what to do next. I have no key and the steering is locked in place. It won't matter if the switch is mangled.
Help Thanks CCLINSTRAIGHTISTHEONLYWAY |
| boxstr |
Aug 26 2005, 05:09 PM
Okay have to go. If you have a solution call me 503-799-5794.
Heading to CAMP 914. Craig |
| goose2 |
Aug 26 2005, 05:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
run Craig!! The COPS are coming!
| mk114 |
Aug 26 2005, 06:02 PM
LOST in NO space (my garage) ![]() ![]() Group: Members Posts: 330 Joined: 29-March 05 From: Salt Lake Utah Member No.: 3,835 |
did that work?
| boxstr |
Aug 26 2005, 08:05 PM
Michael I got my new tires and wheels from Coker for the hot rod. So I worked on that instead. Saturday.
CCLINALONGWAYHOME Attached image(s)
| TravisNeff |
Aug 26 2005, 08:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
The locking pin will stop you from getting that bugger out. Take out the passenger door handle and take it to a locksmith to make a key. Easy 'nuff.
| bd1308 |
Aug 26 2005, 09:18 PM
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
but what if his door handles arent matched, like mine?
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
| TravisNeff |
Aug 26 2005, 09:27 PM
driver side door, trunk locks (either) or the glove box lock. Actually the rear trunk lock would be the easiest to pull. Aside from that, your fuched. Actually not, you can have a mobile locksmith come out and make a key for you on the spot. They did that for me about 10-15 years ago for about $50.00 Of course the next day I found the key I lost (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
I tried like hell to get the switch out of the ignition, using dental picks and crap to try to push in the locking pin. It wasn't working for me, at that point I was looking for a chainsaw. |
| Allan |
Aug 26 2005, 09:37 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Don't feel bad Craig. I was in London one time driving my MG Midget to a wedding reception. Got drunk and lost the key. After the reception the weather was in the single digit area. Tore the entire culumn apart and even talked a shop owner into selling me a hacksaw at 2:00 a.m.
Finally got the car started and as I was driving away one of the cleaning guys from the wedding hall ran over and handed me the key. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
| Rgreen914 |
Aug 26 2005, 09:57 PM
Member ![]() ![]() Group: Members Posts: 285 Joined: 20-October 03 From: West Covina, Ca. Member No.: 1,266 |
I once locked the key to my state vehicle inside while the car was parked in the tunnel under the Long Beach PD station; cars are only supposed to park there while unloading prisoners as the booking area is just inside and the tunnel is often congested by black and whites (the watch sergeant gets highly upset if this tunnel is blocked, especially if it's not one of their cars). Luckily for me, lots of cops carry "slim-jims" in their "bag of tricks" and the problem was quickly solved.
Ron |
| bondo |
Aug 26 2005, 10:12 PM
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Didn't I read somewhere that if you know where to drill you can drill a little hole and depress the locking pin through that? Or was that for something else?
| boxstr |
Aug 26 2005, 10:44 PM
Michael Harris called and gave me a few pointers, so Saturday I will see what happens and get back to you all with the out come.
CCLINKEYINC. |
| boxstr |
Aug 27 2005, 11:09 PM
Okay here we go. The ignition switch can be removed if you do not have a key. I removed the igniton switch by poking a small pin into the small hole you see int eh switch assembly. After that was done you can then push the lock assembly that sits down inside the switch to the right and pull the whole thing out. and VOILA unlocked.
Thank you one and all. CCLINFREEWHEELING Attached image(s)
Lo-Fi Version | Time is now: 17th April 2026 - 05:48 AM |
