> Measurement needed (Subaru alternator), about to make a bracket
TonyAKAVW
post Aug 27 2005, 12:52 PM
That's my ride.
So Im here at my father in laws house in Buenos Aires about to make a bracket for the alternator for my subaru conversion and I left the key dimension for the alternator at ou apartment w are staying in, which is prtty far from here.
So if anyone has access to a 2.5RS alternator and can measure the bolt spacing I would appreciate it a LOT.
Im guessing the WRX uses the same alternator...
-Tony
ArtechnikA
post Aug 27 2005, 01:02 PM
rich herzog
i have an EJ25 alternator in the parts pile waiting to be installed later today; if you thik that'd be the same, i can measure whatver you want. it's from a '97 Legacy Outback with power everything so it's pretty big...
phantom914
post Aug 27 2005, 01:06 PM
non-914-owner non-club member
Sorry, I can't help you and even if I could, I wouldn't. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif)
Andrew
TonyAKAVW
post Aug 27 2005, 01:18 PM
That's my ride.
Thats the exact alternator... I want the spacing between the bolts, i.e. the pivot axis and the tensioning axis.
Thanks!
Kostamojen
post Aug 27 2005, 03:42 PM
17.5cm, thats from the center of the bolt hole to the center of the bolt hole (pivot vs. tension)
ArtechnikA
post Aug 27 2005, 04:03 PM
rich herzog
QUOTE (Kostamojen @ Aug 27 2005, 05:42 PM)
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif)
Matt Monson
post Aug 29 2005, 09:02 AM
For future reference if anyone has to search for this, all EJ series Subaru alternators are the same dimensions. Doesn't matter if it is EJ18, EJ20, EJ22, or EJ255.
And I have a pile of these alternators in my garage if anyone ever needs a good used one for their project...
Cap'n Krusty
post Aug 29 2005, 09:13 AM
Cap'n Krusty
QUOTE (Kostamojen @ Aug 27 2005, 01:42 PM)
What is that in Whitworth? The Cap'n
TonyAKAVW
post Aug 29 2005, 10:47 AM
That's my ride.
Thanks for the dimensions! The bracket is pretty much finished, just have to bolt it together and have a small amount of aluminum welding done here.
We used a variety of machines to make the parts, but the coolest one was my father-in-law's EDM machine. Instead of milling out a channel, or trying to mill out square corners, we just used a pre-made copper plug and set the thing up and let it go.
- Lo-Fi Version Time is now: 10th September 2026 - 02:11 PM
