| d914 |
Aug 27 2005, 02:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,350 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
just got a 911sc front end with a underbody sway, about 19mm, didnt check yet.
I have a 19mm thru body on the car. Options: - use the underbody as is - put new u-tabs on the 911 control arms and use thru body. - mix match 914/control arms with the 911 front???? Can I keep the 19mm torsions that way?? I gotta feeling the answer is cut and weld but thought I'd ask... |
d914 sway bar Aug 27 2005, 02:50 PM
Travis Neff I believe that the SC bar is 22MM and non-adjustab... Aug 27 2005, 02:57 PM
Travis Neff The other thought is to just put it in as is and s... Aug 27 2005, 02:59 PM
flesburg http://www.914world.com/bbs2/h... Aug 27 2005, 03:09 PM
d914 I measured the "new sway" it looks to be about a 1... Aug 27 2005, 03:21 PM
trekkor I have found my 31mm front bar with 200# rear spri... Aug 27 2005, 06:24 PM
Eric_Shea Early 911 underbody bar was 18mm (74-77). 20mm is... Aug 27 2005, 08:09 PM
bd1308 trekkor, link? Aug 27 2005, 09:42 PM
trekkor Marina a/x vid
click it! http:... Aug 27 2005, 10:21 PM
Britain Smith I would recommend a thru-body bar in the front. I... Aug 27 2005, 11:51 PM
maf914 What size front torsion bars do 911SC's use? ... Aug 28 2005, 08:13 AM
johnmhudson111 <... Aug 28 2005, 06:00 PM
johnmhudson111 ![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:25 PM |
