> Ducts for engine cooling, To get those CHTs in control
groot
post Aug 28 2005, 09:14 AM
Dis member
In another thread some of us discussed a variety of methods to get fresh, cool air to the engine to assist in engine cooling.
I ran this setup at M-O last weekend and my CHTs dropped to under 400 degrees for the first time since my engine rebuild. Before these ducts, I could only run 1 or 2 hot laps before my CHTs got too hot. Now, I can run 20 laps at M-O and the temps stay under 400 degrees.
2-3" ducts from each turn signal opening.
Front view with the fender off:
groot
post Aug 28 2005, 09:15 AM
Dis member
Under side of modified NACA duct attached to the turn signal opening:
groot
post Aug 28 2005, 09:16 AM
Dis member
Into the fan housing....
groot
post Aug 28 2005, 09:17 AM
Dis member
Another view of the hose running in the front fender:
Allan
Teenerless Weenie
How do you get it all the way to the engine compartment? Through the rocker panels, passenger compartment??
groot
post Aug 28 2005, 09:19 AM
Dis member
Passenger compartment.... maybe not the best option for a street car.
ChrisFoley
post Aug 28 2005, 08:34 PM
I am Tangerine Racing
Good deal Kevin, looks like a winner!
Aaron Cox
post Aug 28 2005, 08:41 PM
Professional Tinkerer
easier than a naca duct in the rear qtr?? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
looks good
ChrisFoley
post Aug 28 2005, 09:27 PM
QUOTE (Aaron Cox @ Aug 28 2005, 10:41 PM)
looks good
We're only allowed to use existing openings in the bodywork Aaron. Tends to complicate things a bit.
Brett W
post Aug 28 2005, 09:46 PM
Do your tires not hit the ducts in bump and roll?
maf914
post Aug 29 2005, 06:52 AM
Not a Guru!
I remember seeing Bob Kirby's black 914 at the runoffs when they were last held at Road Atlanta (a few years ago!). His car had a round duct routed from the front trunk to the engine fan inlet and a fan with no or few blades. In the front trunk there were rectangular ducts in a Y-shape feeding the round duct from the headlight buckets. Similar concept to Kevin's.
URY914
post Aug 29 2005, 07:09 AM
Nice work. The sheetmental duct at the engine inlet is a good chose.
Paul
groot
post Aug 29 2005, 07:17 AM
Dis member
No interference... I'm running a bit more ground clearance than you're planning, ~4" in the front. I need to run this much to give me 1.25" of travel before the jounce bumper comes in. My strut could be a little shorter to give me more travel, but I'm living with what I have for now.
Many SCCA 914 have the sewer duct, but my package layout does not allow me to run one through the middle of the car.
- Lo-Fi Version Time is now: 30th June 2026 - 08:12 PM
