Help with rear brakes, what am I doing wrong? |
Kevin@ojai.net |
Aug 28 2005, 07:39 PM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
So, a few minutes ago I tried replacing my rear brake pads with out success. I was unable to retract the pistons far enough into the calipers to fit the new pads in. All I did during my failed attempt was remove the old pads, then pry against the pistons. This process has worked for me on other vehicles, but I had almost no luck on the 914. I was able to retract the pistons a little, but not nearly enough to get the new pads installed. What am I forgetting to do? What am I doing wrong?
-Kevin |
Lo-Fi Version | Time is now: 17th May 2024 - 04:48 AM |
