captjm |
Newbie ![]() Group: Members Posts: 16 Joined: 28-January 07 From: Temecula, CA Member No.: 7,485 ![]() |
After bringing the gauge cluster tin to bare metal already, do I powder coat (I have a small powder coating unit) or do I paint it? Should it be gloss or a flat? What do you think? open to suggestions. Thanks!
dtmehall |
Member ![]() ![]() Group: Members Posts: 132 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest ![]() |
I painted mine matte black
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 741 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
Satin black was the original color, if I remember correctly. I painted mine black wrinkle finish to break up the monotony of the 914's black interior and dashboard.
STL914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,195 Joined: 22-October 03 From: O'Fallon, MO Member No.: 1,271 Region Association: Upper MidWest ![]() |
When I had my car painted Jaguar Racing Green I had my gauge cluster plate painted the same color. Wanted to introduce that color into the interior.
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I'd paint.
Powdercoat is thick and doesn't take manipulation well, tends to chip off. I haven't re-installed Porsche bezels before, but most others require bending the lip to secure. I'm not sure PC would accept that. I'd use "low gloss black" Dupli-Color DE 1634 if I was hunting "stock". The body color idea from the previous post might be killer too! Edit: Sorry, thought you were referring to the bezels. Powdercoat might work fine for the gauge plate. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,841 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
VHT SP652 Satin Black Epoxy is a good match.
captjm |
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,026 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
Rust-Oleum Satin black.
Lo-Fi Version | Time is now: 31st July 2025 - 12:13 AM |
