lost low beams, lows down work, highs do |
mikelsr |
Aug 29 2005, 08:00 AM
Senior Member Group: Members Posts: 657 Joined: 2-January 05 From: Mahomet, IL Member No.: 3,390 Region Association: Southwest Region |
I went to take the teener for a night drive and found that I don't have the low beams anymore. The high beams work fine. The only thing I did was to pull out the old antenna lead and put a new one in. I am looking for single point of failures since both lights don't work. One is the fuse (hich is good), second is ground (need to find and check that), and third is a relay (can someone point me to the correct relay). Any other thing I should be looking at?
TIA |
Lo-Fi Version | Time is now: 22nd May 2024 - 01:14 PM |
