Serious Q: Re: Carbs., Running moderate cammed 350 SBC |
Dr. Roger |
Aug 29 2005, 12:10 PM
Got two vac secondary carbs (600 cfm smog carb and a 750) which I now know are in need of rebuilds.
The 600 runs but, on this heavily cammed engine, like *hit. Idle circuit has very little adjustability. And it's got more vacuum ports than I can count. The 750 is a bit too much I think for the 350. I've run 650 double pumpers with great success and am thinking about installing a 650 spreadbore. Small primaries/large secondaries. Goal here is to keep higher velocities off idle for responsiveness and, due to engine displacement, not over carb it like if I used the 750cfm. 6K redline... I'm about ready to go the the local parts place and plunk down some spare change on a new 650. WWYD? =-)) Roger Pic is the 600 smog carb....... Come hear it run.... Swap ya' for that old 650 dbl pumper..... =-))) Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 09:59 PM |
