Replacing Cheesehead Screws |
BMartin914 |
Aug 30 2005, 11:21 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I currently have the bulk of my engine tin off and have ruined a few of the cheesehead screws. I am contemplating whether or not to simply buy some new cheeseheads from the local VW place and make sure to use anti-sieze on them, or should I replace the cheeseheads with another type of fastener altogether.
Any suggestions? BTDT? |
URY914 |
Aug 30 2005, 11:27 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,637 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The one's at the VW shops are pretty cheap. They are chrome and are real soft.
I've used standard hex heads bolts and used allen head bolts. I like the allen heads. The look cool and clean. You can find stainless steel ones at hardware stores or HD or Lowes. P |
Aaron Cox |
Aug 30 2005, 11:28 AM
metric socket head cap screws (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
tat2dphreak |
Aug 30 2005, 11:34 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) i got a box of cool black allen-heads @ the hardware store... |
double-a |
Aug 30 2005, 11:35 AM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i've wondered about this too. what's the thread pitch on those cheeseheads?
~a |
BMartin914 |
Aug 30 2005, 11:38 AM
Looks like we have consensus about allen head cap screws. There are different lengths though, but I guess that doesn't really matter when you are just attaching 2 pieces of tin together - more so when you re-attach the impeller housing to the case.
type47 |
Aug 30 2005, 12:24 PM
6mm
Cap'n Krusty |
Aug 30 2005, 01:46 PM
6mm x 1. VW went to Phillips head screws for the tin in 77 and up, a pretty satisfactory move. As others have said, there are several lengths to consider, but most of the screws are about 12mm long. The Cap'n |
Engman |
Aug 30 2005, 02:30 PM
Zoisite Group: Benefactors Posts: 1,349 Joined: 25-March 03 From: New Albany, IN Member No.: 475 |
SS Allen head - no more rust and you can actually turn em.
M |
yeahmag |
Aug 30 2005, 02:39 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Doesn't stainless steel and aluminum set you up for some pretty nasty electrolosis? The stainless steel screws in the aluminum mast of the sailboat always make a mess... Not that I know of anything better, but some anti-seize and a steel screw may be "just as good".
-Aaron |
Engman |
Aug 30 2005, 02:46 PM
9+ years installed in the engine - did a little work on it this last w/e. Did not see any issues.
M |
URY914 |
Aug 30 2005, 02:48 PM
That may be a problem in about 100 years. |
Qarl |
Aug 30 2005, 02:51 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
double-a |
Aug 30 2005, 03:32 PM
good deal. i'll pick a buncha these up next time i'm over at a-boy hardware. ~a |
Katmanken |
Aug 30 2005, 03:51 PM
Actually,
It's iron and aluminum that cause the iron to rust. The high nickle content in stainless prevents the iron form rusting. I've seen bolts (used in oceanography) made from an iron/aluminum mix that are designed to corrode in seawater. Bolts are time designed to break after immersion. Attach a buoy to an instrument package with a bolt, chunk it over the side and come back in a week. Bolt corrodes and the bouy floats up so you can find it. Accurate within 15 minutes. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Don't be using these for your car (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Ken |
tdgray |
Sep 9 2005, 09:28 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Just FYI.
I went to my local Home Depot yesterday. In thier specialty bolt section they had 6mm x 12mm allen head screws, black, two to a pack. Cost was $1.12 per pack. I bought all they had, about twenty, $11.82 for all. |
goose2 |
Sep 9 2005, 09:38 AM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
You can buy a special thread lube in a tube at a boat rigging shop that will minimize this effect...West Marine may have it. Probably not worth worrying about though. |
Cap'n Krusty |
Sep 9 2005, 09:46 AM
Ya coulda gone over to John Deere or Catapillar and bought about 50 for that much. The Cap'n |
tat2dphreak |
Sep 9 2005, 09:51 AM
or ACE... I bought a box of 50 for $10 |
tdgray |
Sep 9 2005, 10:02 AM
Well F'in shoot me OK (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
I was just letting you know that they had them there. You guys both get your period today (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:44 PM |
