BMartin914
Aug 30 2005, 11:21 AM
I currently have the bulk of my engine tin off and have ruined a few of the cheesehead screws. I am contemplating whether or not to simply buy some new cheeseheads from the local VW place and make sure to use anti-sieze on them, or should I replace the cheeseheads with another type of fastener altogether.
Any suggestions? BTDT?
URY914
Aug 30 2005, 11:27 AM
The one's at the VW shops are pretty cheap. They are chrome and are real soft.
I've used standard hex heads bolts and used allen head bolts. I like the allen heads. The look cool and clean. You can find stainless steel ones at hardware stores or HD or Lowes.
P
Aaron Cox
Aug 30 2005, 11:28 AM
QUOTE (URY914 @ Aug 30 2005, 10:27 AM) |
P |
metric socket head cap screws
tat2dphreak
Aug 30 2005, 11:34 AM
QUOTE (URY914 @ Aug 30 2005, 12:27 PM) |
P |
i got a box of cool black allen-heads @ the hardware store...
double-a
Aug 30 2005, 11:35 AM
i've wondered about this too. what's the thread pitch on those cheeseheads?
~a
BMartin914
Aug 30 2005, 11:38 AM
Looks like we have consensus about allen head cap screws. There are different lengths though, but I guess that doesn't really matter when you are just attaching 2 pieces of tin together - more so when you re-attach the impeller housing to the case.
type47
Aug 30 2005, 12:24 PM
6mm
Cap'n Krusty
Aug 30 2005, 01:46 PM
QUOTE (double-a @ Aug 30 2005, 09:35 AM) |
~a |
6mm x 1. VW went to Phillips head screws for the tin in 77 and up, a pretty satisfactory move. As others have said, there are several lengths to consider, but most of the screws are about 12mm long. The Cap'n
Engman
Aug 30 2005, 02:30 PM
SS Allen head - no more rust and you can actually turn em.
M
yeahmag
Aug 30 2005, 02:39 PM
Doesn't stainless steel and aluminum set you up for some pretty nasty electrolosis? The stainless steel screws in the aluminum mast of the sailboat always make a mess... Not that I know of anything better, but some anti-seize and a steel screw may be "just as good".
-Aaron
Engman
Aug 30 2005, 02:46 PM
9+ years installed in the engine - did a little work on it this last w/e. Did not see any issues.
M
URY914
Aug 30 2005, 02:48 PM
QUOTE (yeahmag @ Aug 30 2005, 12:39 PM) |
-Aaron |
That may be a problem in about 100 years.
Qarl
Aug 30 2005, 02:51 PM
double-a
Aug 30 2005, 03:32 PM
QUOTE (Cap'n Krusty @ Aug 30 2005, 11:46 AM) |
QUOTE (double-a @ Aug 30 2005, 09:35 AM) | i've wondered about this too. what's the thread pitch on those cheeseheads?
~a |
6mm x 1. VW went to Phillips head screws for the tin in 77 and up, a pretty satisfactory move. As others have said, there are several lengths to consider, but most of the screws are about 12mm long. The Cap'n |
good deal. i'll pick a buncha these up next time i'm over at a-boy hardware.
~a
Katmanken
Aug 30 2005, 03:51 PM
Actually,
It's iron and aluminum that cause the iron to rust. The high nickle content in stainless prevents the iron form rusting.
I've seen bolts (used in oceanography) made from an iron/aluminum mix that are designed to corrode in seawater. Bolts are time designed to break after immersion. Attach a buoy to an instrument package with a bolt, chunk it over the side and come back in a week. Bolt corrodes and the bouy floats up so you can find it.
Accurate within 15 minutes.
Don't be using these for your car
Ken
tdgray
Sep 9 2005, 09:28 AM
Just FYI.
I went to my local Home Depot yesterday. In thier specialty bolt section they had 6mm x 12mm allen head screws, black, two to a pack. Cost was $1.12 per pack.
I bought all they had, about twenty, $11.82 for all.
goose2
Sep 9 2005, 09:38 AM
QUOTE |
The stainless steel screws in the aluminum mast of the sailboat always make a mess... |
You can buy a special thread lube in a tube at a boat rigging shop that will minimize this effect...West Marine may have it. Probably not worth worrying about though.
Cap'n Krusty
Sep 9 2005, 09:46 AM
QUOTE (tdgray @ Sep 9 2005, 07:28 AM) |
Just FYI.
I bought all they had, about twenty, $11.82 for all. |
Ya coulda gone over to John Deere or Catapillar and bought about 50 for that much.
The Cap'n
tat2dphreak
Sep 9 2005, 09:51 AM
QUOTE (Cap'n Krusty @ Sep 9 2005, 10:46 AM) |
QUOTE (tdgray @ Sep 9 2005, 07:28 AM) | Just FYI.
Ya coulda gone over to John Deere or Catapillar and bought about 50 for that much. The Cap'n |
or ACE... I bought a box of 50 for $10
tdgray
Sep 9 2005, 10:02 AM
Well F'in shoot me OK
I was just letting you know that they had them there.
You guys both get your period today
Bartlett 914
Sep 9 2005, 10:28 AM
I usually get my screws from MSC (mscdirect.com) or from Metric and multistandard components. Do a google and you wil find them.
Mark
goose2
Sep 9 2005, 06:02 PM
I think you need to go to Wisconsin to get a genuine cheesehead screw.
TravisNeff
Sep 9 2005, 06:08 PM
I went with the factory style fasteners from the local VW place. Looks good aftere a couple years and the price and availability was right.
ninepfourteen
Sep 12 2005, 08:08 AM
McMaster Carr has Cheese heads. Use Milk of Magnesia to prevent galling.
