Boothy |
Member ![]() ![]() Group: Members Posts: 104 Joined: 17-January 19 From: Abington, MA Member No.: 22,805 Region Association: North East States ![]() |
Cheers all!
Following the procedure for setting valves using the ramps. https://www.pelicanparts.com/techarticles/9...7GYJ5aJcmZXoVme It's up, the driver's wheel is off, plugs are out, e-brake is off, and I can't get the driver's wheel to turn. I've tried 1st and 3rd gear. Neutral it all rotates freely. WTF am I missing? |
Shivers |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,012 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California ![]() |
Did you try 5th?
Boothy |
5th worked!!! Thank you!!!!!!
Wish I could send beer through the board. Need that enhancement. (IMG:style_emoticons/default/smile.gif) |
GregAmy |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,493 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States ![]() ![]() |
WTF am I missing? One of these...? https://www.lislecorp.com/specialty-tools/remote-starter I much prefer the Cap'n's procedure...RIP Cap'n, we miss you. http://www.914world.com/bbs2/index.php?showtopic=28758 |
Boothy |
Thanks all. I was skim-reading rather than reading closely. It says fifth. I'm dickhead. (IMG:style_emoticons/default/smile.gif)
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,917 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
I have been looking for a remote starter switch with about a 12 foot lead. They all seem to be 5 ft leads.
Our starters are not accessible from the top engine bay. So connected to the solenoid, it has to route under the car to the drivers side and long enough to be able to stand up and see the dizzy position. 5 ft long is not sufficient |
GregAmy |
For being underneath and adjusting valves using the Capn visual "rocking method" (where you don't need to know which cylinder is TDC) then the cheapie Lisle starter switch works fine.
Though I'd never had the need for it, if i were working on top then I'd run the cable through or around the sheet metal. Maybe remove the heater tube and go through there? Jeff, know anyone that does wiring that could make an extension for it? (IMG:style_emoticons/default/wink.gif) |
Front yard mechanic |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,326 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None ![]() ![]() |
That’s what girlfriends are for
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,926 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
I just used some zipcord the same size as original to cut/splice/extend the leads on my Amazon-purchased starter switch cable.
worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,481 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
I have been looking for a remote starter switch with about a 12 foot lead. They all seem to be 5 ft leads. Our starters are not accessible from the top engine bay. So connected to the solenoid, it has to route under the car to the drivers side and long enough to be able to stand up and see the dizzy position. 5 ft long is not sufficient You get a wire from the starter solenoid. I use yellow. And you run it up towards the battery. Then you touch it to the positive terminal and the motor turns over. Now everyone on the planet is closer to stealing my car. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,350 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Guys guys guys.....Why make it harder???
Just hook the remote starter button to either pin II or IV on the 4 pin connector on the relay board. They are both in the starter circuit. So you don't even have to climb under the car to hook it up. (IMG:http://www.914world.com/bbs2/uploads/post-1143-1694107603.jpg) |
JeffBowlsby |
Guys guys guys.....Why make it harder??? Just hook the remote starter button to either pin II or IV on the 4 pin connector on the relay board. They are both in the starter circuit. So you don't even have to climb under the car to hook it up. Have you done it this way Clay? |
ClayPerrine |
Guys guys guys.....Why make it harder??? Just hook the remote starter button to either pin II or IV on the 4 pin connector on the relay board. They are both in the starter circuit. So you don't even have to climb under the car to hook it up. Have you done it this way Clay? Yes. I have been doing that for years. The ignition switch on Betty's car broke on an out of town autocross and it wouldn't crank. I went to FLAPS and bought a starter button, some wire, a spade terminal and a loop terminal. I wired the start button up, hooked the spade terminal to the connector on the relay board and the loop terminal to the battery. Then I duct taped the button to the air cleaner snorkel. Every time we had to start the car, I had to open the engine lid and push the button. She got all her runs in and we were able to get home. So it works. |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,376 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Wow, sounds like an emergency bit of kit for our elderly cars. Good to know (IMG:style_emoticons/default/beerchug.gif)
I just made one up and will keep the hardware in the tool kit worked fine (IMG:style_emoticons/default/smile.gif) Barefoot |
bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
Cheers all! Following the procedure for setting valves using the ramps. https://www.pelicanparts.com/techarticles/9...7GYJ5aJcmZXoVme It's up, the driver's wheel is off, plugs are out, e-brake is off, and I can't get the driver's wheel to turn. I've tried 1st and 3rd gear. Neutral it all rotates freely. WTF am I missing? Big muscles? (IMG:style_emoticons/default/biggrin.gif) |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,736 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I also usually pull the spark plugs out of the engine so I'm not fighting compression. That way, with the car in 5th gear, I can lay under the vehicle watching the rockers and just turn the wheel with my foot.
Zach |
Lo-Fi Version | Time is now: 21st May 2025 - 10:02 AM |
