| rhodyguy |
Sep 14 2005, 05:47 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
jon, some came off of the engine, some came out of the stash. jim, call/stop by during the daytime. all of these pieces ran $156.32, out the door.
k This post has been edited by rhodyguy: Sep 14 2005, 07:19 AM |
| Bleyseng |
Sep 14 2005, 08:17 AM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Lookin good, gonna have it together today?
| fatlando |
Sep 14 2005, 08:25 AM
Member ![]() ![]() Group: Members Posts: 259 Joined: 6-September 04 From: imperial beach, california Member No.: 2,700 |
kevin,
I finally dropped my motor too! I'm going to seattle Friday evening, are you going to be around so I can drop off your MPS? Aren't you seeing Jeff too? Can you give him my MPS to fix? cya and thanx for the tips. my motor is grungy looking too! |
| rhodyguy |
Sep 14 2005, 08:30 AM
will adjust the valves, temp put on the flywheel, should double check end play. quite a few items to button up before i start installing the tin. dave, check your pm's. Ken's powdercoating did a great job. they put little rubber plugs in all the threaded openings. i don't have to run a tap to clean the threads. i took the stuff in last fri. it was done monday but i picked it up yest. quick turn around. about 1/2 the price of a large coating shop in tacoma.
k |
| goose2 |
Sep 14 2005, 08:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Nice work Kevin...curious about "oil eater" having tried various engine cleaners. What and where is it?
| rhodyguy |
Sep 14 2005, 09:13 AM
randy, i buy it at Costco. Oil Eater is the brand name. it comes in a 1 gallon jug (about $7 iirc), including a spray bottle. not "fumy" like brake cleaner, as in you don't need to wear a respirator, nor will your garage blow up. spray it on let it work. you don't let it dry out. a little brush action and hose it off. repeat as ness. bio degradable. it works great for degreasing smaller items too. i delute it down, put it and the parts in a 5 gal bucket, let them soak. it also will pull old rattle can paint off too. which is a bonus in my book. but, it will dull the finnish on aluminum if you're not careful. cleans the hell out of it tho.
k |
| rhodyguy |
Sep 14 2005, 09:38 AM
Ken's also does ceramic with thermal barrier properties, coatings. i'm considering having the intake runners done with that(like chrome finnish). my only concern is that the heat will be kept out, not sealed in.
k |
| goose2 |
Sep 14 2005, 09:59 AM
Would you trust them to do a set of 6 headers? Cheaper than Jet maybe? |
| rhodyguy |
Sep 14 2005, 10:03 AM
randy, pm to be sent.
k |
| rhodyguy |
Sep 14 2005, 08:04 PM
busy day. adj valves, r&r front inboard engine mounts, check end play (thanks dave hunt), drain oil, discover the vw shop sold me the wrong oil filters "sorry dude. don't know what to tell ya", eat a bowl of chili out on the deck with dave, install tin.
k Attached image(s)
| rhodyguy |
Sep 14 2005, 08:08 PM
asdf. more tomorrow.
k Attached image(s)
| rhodyguy |
Sep 16 2005, 08:35 PM
too black. way too black.
k Attached image(s)
| rhodyguy |
Sep 16 2005, 08:43 PM
better. much better.
k Attached image(s)
| rhodyguy |
Sep 16 2005, 08:44 PM
still a few stray lines to install. new fan belt.
k Attached image(s)
| rhodyguy |
Sep 16 2005, 08:47 PM
Cerama-Chrome. i put the gear lube in the trans too.
k Attached image(s)
| rhodyguy |
Sep 16 2005, 08:49 PM
i should be mating the engine and the trans on sat or sun. hang a few items get things ready for install . hopefully next weekend.
k Attached image(s)
| sixnotfour |
Sep 16 2005, 08:55 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,161 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Is that really Cerama-Chrome, If it is it looks way better in person
Performance Coating in Auburn, Wa. does a good job Too. |
| 914werke |
Sep 16 2005, 09:05 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,581 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
I was wondering the same thing P.C. did the Cerma-Chrome thing on all my heat and HE and exhust stuff and it came out looking ..almost.. like chrome.
Looks good though Kev, I guess now youll be a FI convert. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
| rhodyguy |
Sep 16 2005, 09:12 PM
i took the items in for the Cerama-Chrome yest. how's that for turn around. the guy that does the actual coating has this rountine he's done i'm sure 1000 times. when the CC comes out of the oven it is this dull whiteish finnish, that rubs out pretty bright with fine steel wool. the runners are bright and the rest is the white. i start pacing. "i think there's a problem with my parts". "what do you mean?". " these are bright and those are white". "OHHH!!. you have to rub the parts down!". pretty funny, he had me going. you do you own rubbing out.
k |
| 914werke |
Sep 16 2005, 09:14 PM
Lo-Fi Version | Time is now: 17th March 2026 - 10:13 PM |
