Rear view mirror, Removing |
Bartlett 914 |
Sep 1 2005, 04:44 PM
I have a rear view mirror that was positioned incorrectly. Does anyone know of a way to safely remove one?
Mark |
Midtowner |
Sep 1 2005, 04:45 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
Just wait. It will fall off on its own. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Bartlett 914 |
Sep 1 2005, 04:47 PM
Gee why didn't I think of that! (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
Considering I did this about 10 years ago, Maybe a better solution is around. Mark |
Midtowner |
Sep 1 2005, 04:50 PM
More seriously, I'd try strong dental floss or thin fishing line. You may have to replace the rubber pad that sandwiches between the glass and the mirror base. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Bartlett 914 |
Sep 1 2005, 04:54 PM
Thanks Eric
I think I will give that a try. Maybe some steel wire? Mark |
Jenny |
Sep 1 2005, 04:56 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
Kragens, pep boys, etc. sell a solvent that will dissolve the adhesive. The trick is soaking the area. You'll be lucky to get a fraction of the liquid on the contact point. Most of it runs down your arms or off the can due to the angle of the windshield. It's especially hard if the mirror's mounted too high (as mine is) and there's no room between the targa pad and the mirror. I've heard people suggest using a straw and dripping it down onto the glass. I suppose eye dropper would work as well. Good luck!
Jen |
Bartlett 914 |
Sep 1 2005, 05:10 PM
Thanks Jen.
I will look for some. My mirror is also mounted too high. I am getting tired of looking at the rear frame! Mark |
Joe Bob |
Sep 1 2005, 05:28 PM
Murphy's Law...it will never come off when you want it to....only when it is inconvenient. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Tobra |
Sep 1 2005, 07:35 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
put thread on a needle, enough to hold it up above car, tie it in a knot. Stick needle on top side of double side tape, against glass. Hold thread up, drip solvent on thread, and it should follow thread to needle, and get betwixt the tape and windshield. Protect the dash, as that solvent could not be good for it. I just made that up, but it should work. What do you need to stick it back on? regular double side tape, or what.
Elliot_Cannon |
Sep 1 2005, 07:55 PM
Senior Member Group: Retired Members Posts: 1,922 Joined: 26-March 03 From: Orange County Ca Member No.: 480 Region Association: None |
Just give it a good whack. Sucker comes right off.
cheers, Elliot |
Ray Warren |
Sep 1 2005, 08:00 PM
Member Group: Benefactors Posts: 415 Joined: 1-October 03 From: Canada Member No.: 1,214 Region Association: None |
Be careful I tried that and a chunk of glass came off with the mirror. Cost me a new windshield. |
Elliot_Cannon |
Sep 1 2005, 08:28 PM
But it came off right? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) I forgot to put the LOL thing on the previous post. A good whack only works on my starter solenoid. (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) cheers, Elliot |
SpecialK |
Sep 1 2005, 09:04 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Untested, but I think if you had a heat gun and slowly circled the mirror (spiral motion, mirror being the center), from the outside of the windshield, that it would be enough to break down the adhesive (have an assistant pulling on/ready to catch it), without damaging the glass. But that's all beery.....uh, I mean theory. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Weekend started early..........Happy Labor(less) Day Weekend everyone!! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (Don't hold the heatgun in one place too long or baaaad things will happen (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) ) |
Jenny |
Sep 1 2005, 11:35 PM
It's usually NOT tape that's holding it on. More like a crazy glue type adhesive. I don't know if that responds to heat at all. I figured it's when the glue gets too dry and baked on, it eventually cracks/flakes off. The thread and needle trick sounds good though. I might have to try that. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Jen |
MattR |
Sep 2 2005, 12:08 AM
I used a razor blade, some acetone, and took my time. I started at one corner and worked my way around drizzling some acetone in the crack. It soaked in and got easier.
pfierb |
Sep 2 2005, 05:23 AM
oldest member Group: Members Posts: 606 Joined: 1-May 05 From: The sign of good government in Connecticut is to keep raising taxes Member No.: 4,008 |
Had the same problem so I went to a local glass shop they used a ultra violet heat gun a bunch of razor blades and some kind of solvent before it came off....even then a
small piece of glass chipped off but they filled it in with epoxy so looks perfect now.Take your time don't rush it. Good luck Paul F. |
Tobra |
Sep 2 2005, 01:20 PM
And to reattach, is it just heavy duty double sided tape, or is it super glue? Mine is in my glove box (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif)
Midtowner |
Sep 2 2005, 01:48 PM
If you are patient, you may want to consider one of Dr. Evil's mirror replacement:
http://www.914world.com/bbs2/index.php?act=...4&t=24383&st=20 |
aircooledboy |
Sep 2 2005, 01:52 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
DON'T USE SUPER GLUE
There is a special glue made for attaching rear view mirror tabs. Go to a glass shop, pay them the 5 bucks, and let them do it once and you are done. "Super Glue" type glues create too firm of a bond between the tab and the glass. Since glass and metal have very different expansion rates, you will end up with a crack on a very hot or very cold day. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) Saw it first hand dozens of times when I worked in the auto glass business. |
Rand |
Sep 2 2005, 02:50 PM
Pick up your daughter, she swings her backpack around as she sits down, knocks it right off. BTDT. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Ouch, Ray!!! I've seen several get knocked off, but never seen them take glass with it. (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Guess I'll avoid that advice that says the bigger the hammer the easier it comes off. |
Lo-Fi Version | Time is now: 17th May 2024 - 02:46 PM |
