2 Pages V < 1 2
> 911 Fog Light Switch for Front & Rear lights, Need help wiring…See my labeled diagram
Jett
post Jan 24 2026, 04:16 PM
Post #21
Just tried ours, with the 914 part number. If the headlights are on then I can pull the fog light switch out to turn on the front fog lights and the switch itself lights up but a bit dim. If I then turn the knob to the right the rear fog lights turn on along with the fronts, but this time the switch itself is brighter.
If the headlights are on you can turn the fog lights switch to the right without pulling out and the rear fog light alone turns on and the switch itself is bright.
jim_hoyland
post Jan 24 2026, 04:33 PM
Post #22
Get that VIN ?
I’m looking to do the same; so I and II are used as separate outputs to the front and rear fog lamps
2 Pages V < 1 2
- Lo-Fi Version Time is now: 25th January 2026 - 09:37 AM
