9 Pages V « < 7 8 9
> Girl Friends Revenge Richmond VA, 9 Iron to the 914 in a DC parking garage.
HFC3
post Nov 11 2026, 08:14 AM
Post #161
Random discussion after Joe tore the motor down.
Not in any particular order.
J: It had the stock distributor. .009
H: Change to electronic?
J: Not sure why in your case. If electronic breaks you are stranded.
Cylinder Heads
J: Fly Cut, 3 angle, valve guides are perfect, Springs (once we choose a cam)
H: Change to SS Valves on exhaust?
J: Stay with new steel valves - better life and harder than SS.
H My note: (• Stock exhaust valves are made of hardened, high-carbon steel.)
Crank
J: It is perfect. With the middle bearings bone dry it was not what I expected. Still needs to be checked.
Case Savers
J: Not needed
Balancing
J: Not for what you are building and your RPM range/usage.
Flywheel
J: Needs to be machined. Needs a new pressure plate and clutch.
Bolts
J: We can talk.
Oil Galley Plugs
J: More of a personal decision to Tap and Thread
Oil Pump
J: Looks good on initial inspection. It seemed to be doing a good job. It has to come apart.
Carbs
H: Weber 40's? Any used available?
J: I may have some
H: Major components we are working with:
Biral cylinders (cast iron liners with bonded aluminum cooling fins) for the Porsche 914 and VW Type 4 engines are widely available as big-bore performance kits—most commonly in a 96mm size.
The Web Cam #86 is a popular performance camshaft grind designed for Type 4 / Porsche 914 air-cooled flat-four engines
All of this to see where we stand on cost of the build.
I don't know how anyone can give you a solid estimated until the motor comes apart and you get on the same page as best you can.
Any comments from Joe are my interpretation's. I am sure I may mistake things if they don't add up from my notes.
HFC3
post Nov 11 2026, 06:13 PM
Post #162
Parts are being washed starting tomorrow. I am hoping for pictures as the motor progresses.
HFC3
post Nov 13 2026, 05:16 PM
Post #163
I was going to use the Webcam 86a but the builders choice he offered was the Scat C35 which is similar and cheaper. My choice.
Scat C35 285 duration, .495" lift at the valve $170
Webcam 86a $365
9 Pages V « < 7 8 9
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 17th November 2026 - 06:57 AM
