| meares |
Sep 6 2005, 10:24 AM
Member ![]() ![]() Group: Members Posts: 403 Joined: 23-March 05 From: Atlanta Member No.: 3,800 |
OK.....i can't find an AAR, SOOOOO can i just plug it when the engine gets warm? If it closes the passage way anyway when it warms up, i should be able to plug it right?
| Dave_Darling |
Sep 6 2005, 10:45 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,342 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Plug it all the time, then play with the throttle to keep the RPMs up when the engine is cold. If you just leave the hoses unplugged while the engine is cold, the vacuum leak will be much more than a fully-open AAR lets through, and you'll be sucking unfiltered air in.
Or you could do what one of the guys from the Yahoo group is doing--pick up a ball-valve at your local hardware store and plumb that in place of the AAR. You can open or close the valve by hand (he's gonna use a choke cable type setup) to raise or lower the idle. A bit half-assed (OK, more than a bit when he still has an AAR!!) but it should work... --DD |
| meares |
Sep 6 2005, 10:56 AM
THANK YOU....DD, for the response!!! i've been following that guy's journey on this as well.....i can't believe he wants to use that instead of the AAR!!! c'est le vie....when the REVS drop way down is this when i set the idle? should it be warm....and do i use the little screw on the side of throttle body in conjuction with the screw on top of the ECU or separtly?
| lapuwali |
Sep 6 2005, 11:32 AM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Set the idle with the engine fully warmed up (drive on the freeway for awhile, if possible). Use the idle screw on the throttle body. The knob on the ECU sets idle mixture. Set the idle at the TB, then richen the mixture, then lean the mixture slowly until the engine runs rough, then richen it back up until it's JUST smooth again. Reset the idle speed at the TB after you set the mixture.
What's wrong with your AAR? Is it stuck closed or open? If you have one of the "barrel" style, you might be able to open it and clean it. |
| meares |
Sep 6 2005, 08:40 PM
it's stuck open......don't know if it's a barrel type or not......i just plugged it and it runs fine....thanks for info on how to set the idle, i'll try it tomorrow!!
| Oled |
Sep 6 2005, 08:57 PM
Newbie ![]() Group: Members Posts: 44 Joined: 5-February 03 From: San Antonio, TX Member No.: 247 |
You don't need to use the exact same AAR. There are plenty out there on various Djets and Ljets. You might have to fabricate a mount but it can be placed anywhere in the engine bay. A wire to ground might be required but just about any Valve will work. if you want something little different, just find a normally closed solinoid and have a switch power it for starting and warm up.
ed |
| meares |
Sep 6 2005, 09:07 PM
thanks, but i'd like to keep the AAR....i'll find one soon!!
| North Bay 914 |
Sep 6 2005, 09:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 509 Joined: 25-January 05 Member No.: 3,504 |
I have fixed several AAR valves that were inop, they normally just get stuck, so just spray some sort of penatrating oil in it, let it sit for a couple of days. Spray it during the time it is sitting, just make sure the oil keeps getting where its not been in a long time. Put power on it to see if the valve is rotating. I have a 12V power supply on the bench. Use caution, they get Damn hot! Normally they will work. I have not had one that I couldn't make work. About once a month when I'm in the engine compartment, just give it a quick shot to keep it working...
Lo-Fi Version | Time is now: 8th June 2026 - 02:08 PM |
