Rear Window, How to remove? |
Mike's2nd914 |
Aug 1 2003, 09:19 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
My rear window dropped from the adhesive that was holding it in and has a nasty rattle. How do I remove it to replace the adhesive? It looks like the padding comes out from the top and the bottom just lifts out. Also, what do you recommend to replace the damaged adhesive?
Jeffs9146 |
Aug 2 2003, 05:27 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Removing my rear window was twice as hard as any of you guys seem to have experienced. The bottom seal had a metal wire inside and the sealer that was used was hard as a rock. I managed to get a piece of cable through the top and pull it around the window edge until the window came loose. After cleaning and preping I used the same sealer used on the windshield and made sure it sealed in the corners known for leaking. Two people is highly recommended!
Jeff PS: make sure you have the new rubber trim seal in place! |
Lo-Fi Version | Time is now: 19th May 2024 - 04:01 AM |
