Rear Window, How to remove? |
Mike's2nd914 |
Aug 1 2003, 09:19 PM
Member Group: Members Posts: 109 Joined: 26-April 03 From: Birmingham, AL Member No.: 616 |
My rear window dropped from the adhesive that was holding it in and has a nasty rattle. How do I remove it to replace the adhesive? It looks like the padding comes out from the top and the bottom just lifts out. Also, what do you recommend to replace the damaged adhesive?
Lawrence |
Aug 3 2003, 06:36 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
Actually, once you get in there, the job is fairly simple. Tod is right on with the steps removing the interior pieces - typed out it sounds harder than it is.
If you clean everything, and there are no chips or scratches, glue the glass back in place. Complications come if you have to do rust repair. This is an excellent time to replace the seal, too. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 05:11 AM |
