| nmkimosabe |
Jul 31 2026, 04:18 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
My 1974 1.8 with fuel injection will only start by manually opening the throttle but I can't get it idle and thus run properly. I recently had the AFM rebuilt and replaced the points, plugs, condenser and replaced the CHT sensor but the problem continues as it did before. I've looked for vacuum leaks to no avail with starter fluid. I now seek the expertise of the members of this forum for additional suggestions.
| wonkipop |
Oct 6 2026, 05:05 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,783 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
[quote name='nmkimosabe' date='Oct 6 2026, 10:50 AM' post='3274344']
[quote name='wonkipop' post='3274287' date='Oct 6 2026, 01:29 AM'] [quote name='Superhawk996' post='3274239' date='Oct 5 2026, 03:10 PM'] [quote name='nmkimosabe' post='3274235' date='Oct 5 2026, 04:46 PM'] [quote name='Superhawk996' post='3274227' date='Oct 5 2026, 11:39 AM'] Out of curiosity - did your mechanic keep the CHT that came out? If that is a Bosch 017 on some off chance - those are very hard to come by and someone with a 73’ 2.0L might be able to use it if it tests OK. [/quote] [/quote] I think I will go with your recommendation and pitch it but first I will take it apart for a better understanding of the internal components. Hope all is well down under! [/quote] if you want to do an autopsy - this will help getting it apart. http://www.914world.com/bbs2/index.php?showtopic=350416 if its not in the top portion - rollercell head - and it should be obvious if it is you might want to dig down further and see if its a bearing failure, or perhaps a piece of one of those brushes has lodged in the stator rotor or the bearings have failed. don't bother digging down any further than that. it would be interesting to know where the failure is since it allowed the pump to continue working because they usually suffer sudden death rather than an afterlife as a cripple. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) all is well down here, thanks for asking. spring has sprung after an usually bleak grey wet winter. i got some messages from @Jack Standz who was in my town on a holiday a few weeks ago. i joked with him he brought the sunshine, which literally arrived the day he got here. unfortunately his tour schedule was too tight to get out here to the "retirement un-home" and say hello. hope he had a good rest of holiday, he was off to new zealand which is a lovely place and well worth seeing, esp the south island. |
| nmkimosabe |
Oct 7 2026, 08:30 AM
[quote name='wonkipop' date='Oct 6 2026, 05:05 PM' post='3274377']
[quote name='nmkimosabe' date='Oct 6 2026, 10:50 AM' post='3274344'] [quote name='wonkipop' post='3274287' date='Oct 6 2026, 01:29 AM'] [quote name='Superhawk996' post='3274239' date='Oct 5 2026, 03:10 PM'] [quote name='nmkimosabe' post='3274235' date='Oct 5 2026, 04:46 PM'] [quote name='Superhawk996' post='3274227' date='Oct 5 2026, 11:39 AM'] Out of curiosity - did your mechanic keep the CHT that came out? If that is a Bosch 017 on some off chance - those are very hard to come by and someone with a 73’ 2.0L might be able to use it if it tests OK. [/quote] [/quote] I think I will go with your recommendation and pitch it but first I will take it apart for a better understanding of the internal components. Hope all is well down under! [/quote] if you want to do an autopsy - this will help getting it apart. http://www.914world.com/bbs2/index.php?showtopic=350416 if its not in the top portion - rollercell head - and it should be obvious if it is you might want to dig down further and see if its a bearing failure, or perhaps a piece of one of those brushes has lodged in the stator rotor or the bearings have failed. don't bother digging down any further than that. it would be interesting to know where the failure is since it allowed the pump to continue working because they usually suffer sudden death rather than an afterlife as a cripple. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) all is well down here, thanks for asking. spring has sprung after an usually bleak grey wet winter. i got some messages from @Jack Standz who was in my town on a holiday a few weeks ago. i joked with him he brought the sunshine, which literally arrived the day he got here. unfortunately his tour schedule was too tight to get out here to the "retirement un-home" and say hello. hope he had a good rest of holiday, he was off to new zealand which is a lovely place and well worth seeing, esp the south island. [/quote] Wow that is a very detailed teardown of a fuel pump. I don't think it is something I will try looking at the photos. After spending so much time with my mechanic and car issues I am way behind on home and work projects. We are heading into Winter here and I will be looking forward to Spring. Hope you enjoy the Spring weather and taking one of your cars out for a nice trip or two. |
| Jack Standz |
Oct 7 2026, 04:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 986 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
SOT:
all is well down here, thanks for asking. spring has sprung after an usually bleak grey wet winter. i got some messages from @Jack Standz who was in my town on a holiday a few weeks ago. i joked with him he brought the sunshine, which literally arrived the day he got here. unfortunately his tour schedule was too tight to get out here to the "retirement un-home" and say hello. hope he had a good rest of holiday, he was off to new zealand which is a lovely place and well worth seeing, esp the south island. [/quote] @wonkipop Yes, wherever we go, we quite often hear that we bring sunshine (and rainbows). (IMG:style_emoticons/default/biggrin.gif) And, very sorry that we didn't have compatible schedules (IMG:style_emoticons/default/sad.gif). Hope to meet in-person someday. But otherwise, we did have a wonderful time in Australia and New Zealand. And, as it turned out, our bus driver in NZ had a collection of old Indian motorcycles from the 1930s and 1940s which he admitted was probably due to Burt Munro. Burt's the guy from NZ that came to Bonneville Salt Flats and set a land speed record as covered in the movie "World's Fastest Indian". Suggest everyone first watch the movie and then go to Wikipedia to find out the true story if you are interested. |
Lo-Fi Version | Time is now: 24th November 2026 - 09:09 PM |
