| mepstein |
Nov 2 2026, 05:20 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,997 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
That's a neat piece but shouldn't be needed for what Rory has. Hopefully Martin will reply back with info. |
| sixnotfour |
Nov 2 2026, 10:05 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,425 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
That's a neat piece but shouldn't be needed for what Rory has. Hopefully Martin will reply back with info. Yes, Im waiting to hear too.. At this point I think the gps electronic speedo, makeover is the way to go pianning ahead (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/driving.gif) ... one less cable hanging around. (IMG:style_emoticons/default/shades.gif) |
| mepstein |
Nov 2 2026, 12:43 PM
That's a neat piece but shouldn't be needed for what Rory has. Hopefully Martin will reply back with info. Yes, Im waiting to hear too.. At this point I think the gps electronic speedo, makeover is the way to go pianning ahead (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/driving.gif) ... one less cable hanging around. (IMG:style_emoticons/default/shades.gif) I have the parts to do it. I’ll take pics if you need the info. I think it was around $450 in electronics and the cost of an electric speedo. |
| rgalla9146 |
Nov 4 2026, 07:26 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,021 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Martin Bott replied:
Hi Rory, you need to have a speedo adjustment, or a little gearset to adjust. Can only give the mechanical potential to use a mechanical speedo, but can not give exact speedo result. The parts inside the nosecone are Porsche OEM, but 915 was without this speedo drive that the 914 uses and what you probably use. Will have to do this adjustment for my car also. Regards Martin Bott |
| mepstein |
Nov 4 2026, 09:01 AM
So does that mean a mechanical speedo from a 72-77 911 will work correctly?
| rgalla9146 |
Nov 4 2026, 11:55 AM
| Steve |
Nov 4 2026, 12:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,127 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
So does that mean a mechanical speedo from a 72-77 911 will work correctly? You'd think so right ? I thought I answered that question but did not check the part number of the '72 150mph speedo that I have. Anyone know the part number of a '72 911 speedo ? https://www.ebay.com/itm/223488388370 91164150600 = 180 mph speedometer 91164150200 = 150 mph speedometer I use Auto Atlanta to look up part numbers. https://www.autoatlanta.com/pages/911-70-73-parts/906-00 |
| rgalla9146 |
Nov 4 2026, 03:47 PM
So does that mean a mechanical speedo from a 72-77 911 will work correctly? You'd think so right ? I thought I answered that question but did not check the part number of the '72 150mph speedo that I have. Anyone know the part number of a '72 911 speedo ? https://www.ebay.com/itm/223488388370 91164150600 = 180 mph speedometer 91164150200 = 150 mph speedometer I use Auto Atlanta to look up part numbers. https://www.autoatlanta.com/pages/911-70-73-parts/906-00 Thank you Steve This info will help me to know what is what. I have a friend who has a dormant '72 S ... going to ask to borrow his speedo. Also, I will probably end up removing my '916' rear cover and comparing speedo drives with those in a typical 914 rear cover. Onward |
| sixnotfour |
Nov 4 2026, 03:50 PM
HELP.. @jbell
914-901 vs 915-911 speedometer ratios... (IMG:style_emoticons/default/confused24.gif) I sent jbell an email asking him ??? |
| rgalla9146 |
Nov 4 2026, 08:24 PM
John Bell did a 10K tach and a GT fuel gauge for me a couple years ago. I just went back through correspondence and see that he said that with GPS mph / speedo mph info he could make my instrument work. Someone along the way told me my speedo error was too great to correct in the instrument. I forget who. Looks like some remedies are possible ... |
| jbell959 |
Nov 4 2026, 08:29 PM
Newbie ![]() Group: Members Posts: 14 Joined: 2-May 21 From: CA Member No.: 25,505 Region Association: None |
The ratios of the 914 and 911 speedometers are different, but very close. The 911/912 speedometers are stamped W0.8 and the 914s are W0.77
I believe this corresponds to 800 revolutions versus 770 revolutions per mile. This difference would obviously not explain the 50Mph difference. That is actually 100% off not 50%. Sounds to me like it's an issue with the gearing inside the transmission and the cable is spinning twice as fast as it should be. No way to compensate for that inside the speedometer. |
| sixnotfour |
Nov 4 2026, 11:30 PM
@jbell ,, Thank You for your Knowledge...
Looks like this the cure,, If you have to run a cable mag915..Im not.. GPStoshortcable. pick a ratio Trans.. Attached thumbnail(s) |
| mepstein |
Nov 5 2026, 07:04 AM
I don’t believe the real 916 kit had that issue. I wonder what is different?
| rgalla9146 |
Nov 5 2026, 10:03 PM
I have disassembled 914 transmissions and rear covers with the speedo gears included. Does anyone have a 915 rear cover and speedo drive open to do a comparison ? I do know that our 914 90 degree angle drive ratio is !:1 Could the 915 speedo drive gear ratios be so different ? I also have a ('70-'71) 911 trans to compare with. |
| sixnotfour |
Nov 6 2026, 12:00 AM
Well ,,I just got the Necessary parts from Johnny Walker..didnt think twice..
Sent em to Martin..Moved 1200 miles..6yrs later..All this came up... Well the Gear was Double Trouble... (IMG:style_emoticons/default/slap.gif) Hmm, looks like a reduction in speed is needed.. (IMG:style_emoticons/default/blink.gif) ![]() What do think John ? @jbell |
| rgalla9146 |
Nov 6 2026, 11:01 AM
Shown with green background is the 914 speedo gear train. The other shows the interior of a 915 rear cover which should be the same as a replica 916 cover. The shaft shown by 'sixnotfour' fits between the boss at upper left and the gear at lower right. Could the correct companion gears be machined off one shaft and pressed/silver soldered onto the other to create the ratio we need ? ... space permitting ? Anyone ? Attached thumbnail(s) |
| sixnotfour |
Nov 8 2026, 10:38 AM
The exit ratio of the MB conversion versus the 914 .. more or less.. (IMG:style_emoticons/default/wacko.gif)
gear count calculations needed... ![]() ![]() |
| sixnotfour |
Nov 8 2026, 10:57 AM
Im Sure enjoying GRNMNEE's 8:31, aluminum case, electro. speedo.. at the momement.. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/aktion035.gif)
| Steve |
Nov 8 2026, 09:01 PM
Im Sure enjoying GRNMNEE's 8:31, aluminum case, electro. speedo.. at the momement.. (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/aktion035.gif) That's not very nice! (IMG:style_emoticons/default/laugh.gif) but yes the 8:31 stock Electronic speedo was plug and play. No more bouncy speedometer. I did see that Ron also bought the mechanical speedo option and he didn't mention any issues with it. Have you tried to reach out to him? http://www.914world.com/bbs2/index.php?s=&...t&p=1891436 (IMG:style_emoticons/default/beerchug.gif) |
| sixnotfour |
Nov 8 2026, 10:37 PM
(IMG:style_emoticons/default/stirthepot.gif)
I sent Ron a message... He maybe the simple soloution.. BTW Ron Rory and I all bought the same kit same time... (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 14th November 2026 - 11:58 PM |
