| DC_neun_vierzehn |
Nov 2 2026, 08:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 693 Joined: 16-November 20 From: Coastal Delaware Member No.: 24,893 Region Association: MidAtlantic Region
Last night, I think my throttle cable snapped. I believe it snapped somewhere in the tunnel (bc it's still attached at both ends). Bummer bc I just put it on about 6 months ago. I thought I avoided wrapping it around the clutch cable, but I must not have.
Thus, I thought I would replace both cables "while I'm in there" this time (in case the wrapping/rubbing did any damage to the clutch cable). I thought I read in a post recently that if installing both cables, install the throttle cable first, then the clutch calbe, to help avoid the wrapping issue. Is that the correct order? I have a bore scope that I will use and will obviously be more careful this time. Any other helpful tips are welcomed. |
| BillC |
Nov 2 2026, 08:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 761 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region
I don't think there's really any order difference. I would just recommend doing them one at a time, which should make it easier to keep the two cables straight.
Also, check your engine ground -- a snapped clutch or throttle cable can often be a sign of a bad ground and the engine grounding through the cable. |
| DC_neun_vierzehn |
Nov 2 2026, 09:50 AM
Also, check your engine ground -- a snapped clutch or throttle cable can often be a sign of a bad ground and the engine grounding through the cable. Please tell me more. I have no idea what this means. Are you saying to check the ground strap on the transmission to ensue a tight clean fit? |
| Shivers |
Nov 2 2026, 10:02 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,715 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Also, check your engine ground -- a snapped clutch or throttle cable can often be a sign of a bad ground and the engine grounding through the cable. Please tell me more. I have no idea what this means. Are you saying to check the ground strap on the transmission to ensue a tight clean fit. What he means is if your grounds, engine and trans are not making good contact at the ground straps that the electricity will follow the least path of resistance. Which can end up your cables. Look at the size of the grounds compared to the size of your cables and imagine the 12 volts running through them instead of the ground straps. They can turn brittle and break sooner than they should. |
| DC_neun_vierzehn |
Nov 2 2026, 10:30 AM
Also, check your engine ground -- a snapped clutch or throttle cable can often be a sign of a bad ground and the engine grounding through the cable. Please tell me more. I have no idea what this means. Are you saying to check the ground strap on the transmission to ensue a tight clean fit. What he means is if your grounds, engine and trans are not making good contact at the ground straps that the electricity will follow the least path of resistance. Which can end up your cables. Look at the size of the grounds compared to the size of your cables and imagine the 12 volts running through them instead of the ground straps. They can turn brittle and break sooner than they should. Got it. I recently checked all of my grounds and they were good. Will recheck. |
| DC_neun_vierzehn |
Nov 4 2026, 01:05 PM
Well I dug into the job last night.
Good news: I don’t have to replace my cables). After removing pedal board I discovered that the threaded ball socket attachment at the end of the throttle cable had simply popped off of the ball where it connects to the pedal assembly. Before popping it back on, I looked into the tunnel with a scope and noticed the throttle cable was wrapped around the clutch cable. I got that addressed and then reattached the ball socket. So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)? Or can the metal on the ball socket open up a little after 50 years, and lead to a loose fit that’s prone to popping off? Has anybody had this problem? |
| DC_neun_vierzehn |
Nov 5 2026, 09:54 AM
Duplicate post
| DC_neun_vierzehn |
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs?
| BillC |
Nov 5 2026, 10:53 AM
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs? Yes, if you have the kind of socket that has a little circumferential spring inside the opening of the socket cup -- that little circular spring can loose tension and the socket pops off easily. I prefer the socket version that uses an external retainer spring that slides into two holes in the socket and then clips around the socket shaft. This version generally won't pop off unless there is significant damage to the cup or retainer. And, if you don't have a retainer spring, either kind, the socket won't stay on at all. So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)? Generally, if your throttle cable is wrapped around the clutch cable, you'll know because your gas pedal will want to move whenever you press or release the clutch. I think it's more likely that your throttle cable wrapped itself around the clutch cable after the worn socket popped loose. |
| DC_neun_vierzehn |
Nov 5 2026, 05:11 PM
Do the ball sockets attachments at the end of the throttle cable wear out and lead to occasional pop outs? Yes, if you have the kind of socket that has a little circumferential spring inside the opening of the socket cup -- that little circular spring can loose tension and the socket pops off easily. I prefer the socket version that uses an external retainer spring that slides into two holes in the socket and then clips around the socket shaft. This version generally won't pop off unless there is significant damage to the cup or retainer. And, if you don't have a retainer spring, either kind, the socket won't stay on at all. So here’s my question: would the wrapping cause the ball socket to pop off (6 months after installing the throttle cable)? Generally, if your throttle cable is wrapped around the clutch cable, you'll know because your gas pedal will want to move whenever you press or release the clutch. I think it's more likely that your throttle cable wrapped itself around the clutch cable after the worn socket popped loose. @BillC Rut-ro. I didn't see any sort of springs on this ball socket. Can you share pics of either version so I know what's missing? These pics are not my car, but this is the ball socket I'm talking about. Where are the springs in these pics? |
| 914werke |
Nov 5 2026, 07:14 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,796 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Make sure the jamb nut is tight to the socket, if it snaps onto the ball positively you will be fine
| BillC |
Nov 6 2026, 10:02 AM
Rut-ro. I didn't see any sort of springs on this ball socket. Can you share pics of either version so I know what's missing? Those are pics of sockets that have the retaining spring in the hole. If you look in the hole in the socket (where the ball goes), there will be a groove near the opening. In that groove should be a small circular spring clip. That clip retains the socket on the ball. If the spring clip is missing, or if it lost tension, the socket can pop off the ball easily. And, it is common for those spring clips to wear and/or lose tension over time, and usually you only get a certain number of times the socket can be popped off the ball before you need to replace the socket. Here's a (small) pic of the other kind of socket I was talking about: ![]() You can see the retaining spring that fits in a through-hole in the socket and then clips around the shank of the socket. This type seems more secure to me, and more re-usable as well. Another pic I found: ![]() |
| DC_neun_vierzehn |
Nov 8 2026, 04:39 PM
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part?
Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 |
| StarBear |
Nov 8 2026, 04:50 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,386 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Hmmmm. I might check mine as part of my season end decommissioning. Have never noticed or looked at it before.
| BillC |
Nov 8 2026, 07:28 PM
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part? Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 If it were me, I'd buy the type I pictured above, with the external retaining spring. The stock type will also work, I just prefer the external retainer type. |
| DC_neun_vierzehn |
Nov 9 2026, 08:05 AM
So if I'm going to buy a ball socket piece replacement ... should I buy the Genuine Porsche part or an upgraded aftermarket part? Auto Atlanta sells the Genuine Porsche part for $26 (buying direct from a Porsche dealer is a few bucks less): https://www.autoatlanta.com/products/ball-c...=46741533786249 If it were me, I'd buy the type I pictured above, with the external retaining spring. The stock type will also work, I just prefer the external retainer type. Do you have a link that you can share? |
Lo-Fi Version | Time is now: 11th November 2026 - 07:39 PM |
