It's Alive, no more jack stands |
MarkV |
Sep 14 2005, 01:28 AM
Took it apart in November.
New engine shelf, outer pass wheel well, bat tray & support, painted the engine bay, Jake 96mm pistons & bored cylinder, Len Hoffman: welded heads for 12mm plugs, new seats, valves guides, studs, springs & retainers, powder coated tin........................ Attached image(s) |
MarkV |
Sep 14 2005, 01:43 AM
as
MarkV |
Sep 14 2005, 01:44 AM
er
MarkV |
Sep 14 2005, 01:45 AM
gh
MarkV |
Sep 14 2005, 01:47 AM
li
MarkV |
Sep 14 2005, 01:49 AM
asdf
redshift |
Sep 14 2005, 01:50 AM
I have never EVER seen cleaner PR toobs!
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) WtG! M |
MarkV |
Sep 14 2005, 01:51 AM
last
MarkV |
Sep 14 2005, 01:56 AM
Charging system doesn't work.
Got an exhaust leak at the head on the pass side. Need to sink the carbs & see if it will pass emissions. Runs great though, no oil leaks, pulls strong, no smoke. Looking forward to some (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Tom Perso |
Sep 14 2005, 04:58 AM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
Accck! Get rid of that FRAM filter - put something decent on it. Junk!
Other than that, it looks clean clean clean. Good decision with Jake's 96's (I have a set as well) and Len's heads. That thing will run for a nice, long time. Have fun with it!!! Tom |
ArtechnikA |
Sep 14 2005, 06:40 AM
agree on the Fram...
and this is just a pet peeve of mine which you are free to ignore: putting a "No Oil" tag on the filler is confusing. does that mean you shouldn't add more, because it's already full? (or that there is no oil in the engine? ...) IMO - the "No Oil" tag belongs on the coil wire that is taped to the side of the coil, making sure you can't start the engine until you address the situation... |
BMartin914 |
Sep 14 2005, 07:44 AM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
Can you enlighten me to what the advantage of changing the sparkplug from a 14mm to a 12mm is?
URY914 |
Sep 14 2005, 08:12 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,304 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Heads tend to develop a crack between the s/p hole and the valve. By going to a s/p with a smaller diameter you add more material to the area and it won't crack. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
URY914 |
Sep 14 2005, 08:18 AM
I knew someone was going to flame you on that Fram filter (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
It does look good. (Of course it will never look like that again.) Keep going, great job. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
MarkV |
Sep 14 2005, 10:58 AM
I knew I would get a flame job over the (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) filter. What can I say, I am a CSOB I have 3 Mahle filter on the shelf in the garage. Running non detergent oil and (IMG:http://www.914world.com/bbs2/html/emoticons/stromberg.gif) filter for the fist 50 miles, then I will change the oil & filter and adjust the valves.
Jake Raby |
Sep 14 2005, 05:19 PM
I sell both Bosch and Mann/ Mahle filters in my store- use nothing else!!!!!!!!
AZ914 |
Sep 14 2005, 05:31 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
MarkV |
Sep 14 2005, 05:41 PM
Thanks.
Just failed emissions so I will have to get that sorted before (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:14 AM |
