Parking Brake Question, Need help --> A real easy one! |
aveale |
Sep 14 2005, 06:32 AM
Fun Times Group: Members Posts: 194 Joined: 18-August 04 From: Ottawa, Canada Member No.: 2,563 |
Family,
I had my Longs done by MIKES 914s in Cobourg Ontario (AWESOME JOB!!). In so doing, by parking brake indicator light no longer lets me know when the brake is engaged. CAN SOMEONE TELL ME EXACTLY WHERE THE PUSHBUTTON SENSOR IS SUPPOSED TO BE AND WHERE THE WIRE THAT SENDS THE SIGNAL ORIGINATES FROM (i.e. transverse brace OR along Drivers side longitidinal etc). Thanx in advance! T |
ClayPerrine |
Sep 14 2005, 09:52 AM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Take out the driver's seat. There should be a brown with a white tracer wire coming out of the tunnel on the left rear, behind the driver's seat. It should follow along the firewall, and turn forward on the driver's long, then go into a hole with a grommet under the park brake handle. It connects to a switch mounted in the crossmeber. The switch is identical to the door jamb switches for the dome light.
When the park brake is down, it presses the switch, opening the circuit. If you ground the wire and the brake warning light comes on, then you know the electrical part is working. Hope that helps. |
aveale |
Sep 14 2005, 09:58 AM
Clay,
that is exactly what I needed. Hope all is well in Tx. T |
ClayPerrine |
Sep 14 2005, 10:01 AM
I wouldn't know.. I am in AZ on business. 1200 miles from my teener.. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Let me know if that helps. |
Lo-Fi Version | Time is now: 17th May 2024 - 01:05 AM |
