Tobra |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 ![]() |
My outside rearview mirror has clouded a bit. Is there a method for replacing the glass part. I would suspect that a glass shop could cut a piece of mirror to fit, but how to secure it?
Anyone ever done this? Figured it would be a common problem, but search did not really help. |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If it's a stock mirror, you can remove the glass several ways. First, you can just break it, then deal with the pieces. Or you can carefully pry out the black plastic stuff around the glass--that is what holds it in. The plastic tends to be somewhat fragile by this point in time, so it is easy to break. Did I mention it is NLA?
That said, I konw a number of people who have successfully removed the glass from the mirror. Or heck, you could just have a new piece glued on top of the old glass. --DD |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
Couldn't you just glue the sucker on there ? (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Tobra |
so it can't be done with the OEM plastic seal, perhaps I will take a broken one and see if any glass shops have any ideas. Black silicone caulk would be pretty ghetto, but you would probably have to closely inspect it to notice
porsche944Turbo |
Newbie ![]() Group: Members Posts: 8 Joined: 14-September 05 From: San Diego, CA Member No.: 4,799 ![]() |
Hey man, that happened to me too. On my 944, the right view mirror started coming off little by little due to the sound system and bass that a 1200W amp makes, anyway, i was able to save the mirror, took it out completely ,and crazy glued it back on. Its been two weeks and no sign of weakness. for me, crzy glue worked. by the way, i put the mirror on top of the black film thats under it. Hope this helps
Lo-Fi Version | Time is now: 8th July 2025 - 10:49 AM |
