| Mueller |
Sep 20 2005, 04:25 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
shouldn't matter.....once you remove the air flow meter from your L-Jet, they are pretty darn close to being the same with regard to parts that can be kept (throttle body, injectors, sensors*) *unless GM or new Bosch specific sensors are mandatory |
| bug man nrg |
Sep 22 2005, 06:34 AM
Member ![]() ![]() Group: Members Posts: 66 Joined: 17-September 05 From: florida Member No.: 4,811 |
you can the stock sensor's with this unit .you do not need the mas air .you will use a map sensor that reads from the manifold (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
Lo-Fi Version | Time is now: 1st May 2026 - 01:30 AM |
