Turbo Valve Covers, how to modify? |
goose2 |
Sep 17 2005, 02:53 PM
Senior Member Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
Got turbo type lower valve covers on 3.0 and need to know how to modify them so they will come off ok after the motor is installed. I understand some material needs to be removed but I have never seen them done. Does anyone have photos of this mod? It would not be cool to get the motor in and find I have to pull it again to adjust valves. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
Thanks |
Eric_Shea |
Sep 17 2005, 03:00 PM
Pretty straightforward...
You can take .40 off the passengers side (I believe). My old car at Jim's has the mod. Maybe Mr. Chambers can snap some pics. Take them to a machine shop and have them mill off the amount needed. Simple and cheap. E. |
goose2 |
Sep 17 2005, 03:04 PM
Thanks Eric...sounds easy enough...but I thought I read that just the corners (which ones?) need to be machined.
(PS....haven't forgotten your cores. Just holler if you're in need) |
J P Stein |
Sep 17 2005, 03:19 PM
I used a belt sander, pass side, from the back fwd about 1/3 the length, .400 depth seems about right. Do not install the motor with the covers on. If you can put them on with the motor in place, you've cut far enuff.
goose2 |
Sep 17 2005, 03:24 PM
Brilliant (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) ...........why didn't I think of that? |
sixnotfour |
Sep 17 2005, 03:25 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
<!-- QuoteBegin --></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'><!-- QuoteEBegin -->You can take .40 off the passengers side (I believe). My old car at Jim's has the mod. Maybe Mr. Chambers can snap some pics<!-- QuoteEnd --></td></tr></table><span class='postcolor'><!-- QuoteEEnd -->
Das Boat has a freshly milled set too. |
J P Stein |
Sep 17 2005, 08:36 PM
Yes, I noticed you have a mill. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Porsche Rescue |
Sep 17 2005, 09:05 PM
Sounds like you got all you needed from the wise men who posted above, but if you want pics let me know.
Joe Bob |
Sep 17 2005, 09:17 PM
I use a bench grinder......do the deed after the engine is in......ain't rocket science. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Grind, fit, grind again.......best to wash off with a solvent before install to get all the ground off metal flakes.... |
goose2 |
Sep 17 2005, 10:25 PM
have belt sander, have friend w milling machine...will install moto first
........thanks all (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
ein 6er |
Sep 18 2005, 05:03 PM
Senior Member Group: Benefactors Posts: 1,115 Joined: 11-February 03 Member No.: 300 Region Association: None |
a tech article on PP with pics ... here .
goose2 |
Sep 18 2005, 05:23 PM
that helps...thanks |
Lo-Fi Version | Time is now: 15th May 2024 - 12:34 PM |
