goose2
Sep 17 2005, 02:53 PM
Got turbo type lower valve covers on 3.0 and need to know how to modify them so they will come off ok after the motor is installed. I understand some material needs to be removed but I have never seen them done. Does anyone have photos of this mod? It would not be cool to get the motor in and find I have to pull it again to adjust valves.
Thanks
Eric_Shea
Sep 17 2005, 03:00 PM
Pretty straightforward...
You can take .40 off the passengers side (I believe). My old car at Jim's has the mod. Maybe Mr. Chambers can snap some pics.
Take them to a machine shop and have them mill off the amount needed. Simple and cheap.
E.
goose2
Sep 17 2005, 03:04 PM
Thanks Eric...sounds easy enough...but I thought I read that just the corners (which ones?) need to be machined.
(PS....haven't forgotten your cores. Just holler if you're in need)
J P Stein
Sep 17 2005, 03:19 PM
I used a belt sander, pass side, from the back fwd about 1/3 the length, .400 depth seems about right. Do not install the motor with the covers on. If you can put them on with the motor in place, you've cut far enuff.
goose2
Sep 17 2005, 03:24 PM
QUOTE |
Do not install the motor with the covers on. If you can put them on with the motor in place, you've cut far enuff. |
Brilliant ...........why didn't I think of that?
sixnotfour
Sep 17 2005, 03:25 PM
<!-- QuoteBegin --></span><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE </td></tr><tr><td id='QUOTE'><!-- QuoteEBegin -->You can take .40 off the passengers side (I believe). My old car at Jim's has the mod. Maybe Mr. Chambers can snap some pics<!-- QuoteEnd --></td></tr></table><span class='postcolor'><!-- QuoteEEnd -->
Das Boat has a freshly milled set too.
J P Stein
Sep 17 2005, 08:36 PM
QUOTE (sixnotfour @ Sep 17 2005, 01:25 PM) |
The Das Boat has a freshly milled set too. |
Yes, I noticed you have a mill.
Porsche Rescue
Sep 17 2005, 09:05 PM
Sounds like you got all you needed from the wise men who posted above, but if you want pics let me know.
Joe Bob
Sep 17 2005, 09:17 PM
I use a bench grinder......do the deed after the engine is in......ain't rocket science.
Grind, fit, grind again.......best to wash off with a solvent before install to get all the ground off metal flakes....
goose2
Sep 17 2005, 10:25 PM
have belt sander, have friend w milling machine...will install moto first
........thanks all
ein 6er
Sep 18 2005, 05:03 PM
a tech article on PP with pics ...
here .
goose2
Sep 18 2005, 05:23 PM
