Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lawrence |
Aug 4 2003, 12:58 PM
The springs are yellow - didn't see any numbers or brand names when I cleaned them up.
The perches at the bottom have three different positions. They both came set in the middle, so I left them there. I think dropping the perch to the bottom position would give the spring some more movement. There is a significant amount of preload on those springs the way I've assembled them. So... swap them and see what changes? |
Lo-Fi Version | Time is now: 20th May 2024 - 05:51 PM |
