Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
J P Stein |
Aug 4 2003, 01:22 PM
QUOTE(acox914 @ Aug 4 2003, 11:17 AM) how do you know if they are progressive? explain. are they wound loose on the bottom and tight on the top? Ayup...or vice versa....ya get a decent ride, tho, but a guy going for 180 lb springs ain't looking for a smooth ride, IMO. |
Lo-Fi Version | Time is now: 20th May 2024 - 07:07 PM |
