Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lawrence |
Aug 4 2003, 01:33 PM
QUOTE Diagonally......raising the rt front drops the left rear,yada....... Okay.. first I'll try raising the left-front a little bit. Maybe that will balance it out. Small changes in front make larger changes in the back? |
Lo-Fi Version | Time is now: 17th May 2024 - 08:12 AM |
