Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
J P Stein |
Aug 4 2003, 01:48 PM
QUOTE(Lawrence @ Aug 4 2003, 11:33 AM) Small changes in front make larger changes in the back? I dunno.....it would depend how stout your rear springs are, me thinks. I've never been that far out of whack... Put the car on a level surface, start measuring. I measure to the doughnuts...prolly not the best idea, but it's all I got. In the front, double check to the front T-bar mounts. Cheep, quick, and dirty corner ballance. My car has a 1/4 inch twist....using the doughnuts.....last I checked. The measurements don't need to be the same at all four points, just side to side. |
Lo-Fi Version | Time is now: 21st May 2024 - 01:02 AM |
