Ride height - uneven, from shock replacement? |
Lawrence |
Aug 4 2003, 12:42 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
My 914/6 was level before I replaced the rear KYBs with Koni Yellow Adjustables.
Now it's not level. In the back, the right side is about 1.5" higher than the left. I've inspected, and don't see that the springs are messed up - maybe I don't know what to look for. Springs went back into the side that they came out of. Both spring perches are set at the same "notch" on the shock (the middle one). The wheels aren't tilting out like the console is about to collapse. It doesn't appear to affect ride quality - but I sure look like a dork. What might the problem be? Never had this problem with shocks before. -Rusty (IMG:style_emoticons/default/smoke.gif) |
mskala |
Aug 4 2003, 10:27 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Lawrence,
Been there, the front most definitely affects the rear. If you are confident in having the rear springs correctly in the perches, then put the rears on the same slot and forget about them. Adjust the front to get close to level. When/if you do corner weighting, you will not be necessarily level when car is correct. Also, do you have sway bars? They could have preload. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:51 AM |
