> Tarn-X and Electrical Connections
Tobra
post Sep 19 2005, 08:58 AM
I got to thinking after cleaning up my fuse block a bit and replacing my headlight relay. The connectors have a nice patina of age, because they are old. I remember seeing a commercial for this stuff that makes copper look shiny and new, has anyone ever tried this, and if so, how did it work?
I figure less resistance is better for 30 year old wiring, and shiny is better than dingy and green.
Tobra
post Sep 22 2005, 10:25 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
any comments? Seems like a not too bad idea.
Flat VW
post Sep 22 2005, 10:53 AM
Illegal Soapbox Derby Racecar
I would be inclined to use a "true" electricial contact cleaning product, no need to "re-invent the wheel".
John
Mark Henry
post Sep 22 2005, 01:12 PM
that's what I do!
This stuff is the best...But it.s about $50. (Canadian) for a very small bottle. Lasts a long time though.
http://www.stabilant.com/bccomp.htm
Tobra
post Sep 22 2005, 02:24 PM
Looks like I could run down to NAPA and pick some of this stabilant 22 up when I get my butyl tape for the rear window. Should be good for cleaning up my grounds and contacts for my starter too. Thanks, you rock.
smg914
post Sep 22 2005, 04:00 PM
Sahara Beige Steve
The contact cleaner I recommend is: De-Oz-Id
It comes in a small aerosol spray can.
bondo
post Sep 22 2005, 04:02 PM
I've used CLR to clean electrical contacts. It works well, but I always make sure that it gets rinsed VERY well, as it is an acidic product and would probably make it worse instead of better if left on.
- Lo-Fi Version Time is now: 8th July 2025 - 10:46 AM
